Do the SL65 Sparks need to be gapped ?
So I installed SL65 spark plugs NGK G-Power Plug Spark 24 of them! I didnt gap them, do they come already gapped ? or do they require gapping to a certain spec?
EVERY spark plug should be checked for gap before install.
Originally Posted by SL65MONSTA
(Post 6698323)
(Post 6698323)
Yours may have come with the right gap, but I would find out for sure. Nick |
Originally Posted by boostd
(Post 6699236)
Are you trying to see if the plugs corrects your tune issue?
Originally Posted by Welwynnick
(Post 6699431)
Definitely yes (learned the hard way). I fitted up-gapped plugs to mine and it miss-fired. I had to remove them all and re-gap them. Mine came with 1.0mm gaps, which is what the NA engine uses. Turbos have to be gapped to 0.7mm.
I use either NGK IFR6Q-G
http://www.ngkpartfinder.co.uk/car_c...ra.php?id=8319 or Bosch FR 7 KI 332 S (0.7mm) http://www.bosch-automotive-catalog....3FautoLoad%3D1 You will often see the FR 7 KPP 33 U+ listed (1.0mm), but this is for the NA engine: http://www.bosch-automotive-catalog....3FautoLoad%3D1 Nick |
just got an email from NGK they come spaced already :) so I guess that rules that out
OK, but they've got to be the right part number. NGK do say you shouldn't re-gap plugs because is changes the geometry and durability of the spark gap.
Vendors often get it wrong. For example, my reputable local motor factor told me the right plugs were FR7KPP33U+. Nick |
Well there are four types of NGK plugs you can go with depending on your choices. All are compatible with our vehicles
turned out to be a bad coil pack in the end, spark plugs are completely compatible with our cars and work just fine if not better! never listen to naysayers!!
