SL/R230: Is removing exhaust/ cat on sl65 DIY?
can anybody please post a link?- how would one go about removing exhausts ?
-is a cat delete on a sl65 going to bring extra Hp? My exhaust shop says they help spool up the turbos and doing so will make it go slower.
I am no expert on these cars exhausts systems any valuable information much appreciated on this topic
everybody waiting to have a cheap shot at me really , why ? Because in other posts I've proven a lot of people wrong on a certain issue ? Honesty grow a set
There are several other models that use the V12TT besides your SL. You could poke around in those forums for performance enhancements here as well as Benzworld.
Good luck,
Bob
Good luck,
Bob
Help will be scarce as there are not many of us mortals in that lofty V12TT world!
Bob
Might want to emphasize LISTENING to them, not just checking with them.
I might suggest not tearing the rest of the car apart until he gets it running right from the last fiasco. 'course, I'm probably not an expert.
The are four lambda sensors, so first disconnect two above and two below.
The catalysts and downpipes are one and the same thing.
You need E-torx sockets to remove the forward clamps (they're awkward to access) and there are clamps at the rear.
The procedure sounds straightforward, but its never that easy, everything is always corroded and seized.
Obviously, you'll make no friends by claiming to have proved other people wrong in other threads.
Nick
Sorry what do you mean " it doesn't seem to be working out for him ?"
Another example is with the coil heat shield designs I dont agree to the custom ones you made nor do I have to this is the whole beauty of discussion it expands ones ideas and learning process as to why someone would "agree" or "disagree" , simply put I believe them sheilds are designed to allow a rubber hose to pass over and also to keep the heat of the intercooler piping shielded, and until otherwise proven wrong or shown otherwise I will maintain this idea. Doesn't mean if someone agrees or disagrees they are your friend or not. Its okay to have differing opinons on matters and still respect one another.
Did you end up getting them ohm readings and how you did it on the coils
I did before and after temperature measurements, and the custom heat shields reduced the peak operating temperature of the coil packs by 10 deg F.
Therefore they're doing their job, and its not a matter of agreeing or disagreeing.
Nick
10 F may be a small improvement, but it is an improvement, its not worse, and its not negligible. The coil packs run at close to the engine coolant temperature, and electronics become very unreliable when run continuously at much over 200 F. They're unreliable enough as they are, so any extra margin is welcome.
Any of the Mercedes V12TT are difficult to maintain, and I think many of the problems are caused by engine heat. I've tried many different heat management techniques, as you can see in my signature threads. Not all of them were successful - such as insulating the intercoolers, which I don't recommend to anyone. On the other hand, insulating the ABC hoses is a huge win, and I think everyone should do it, and stop winging about the unreliability of ABC when they can do something about it.
Coil pack heat shields are probably a modest win. Although they run cooler, I don't think they will help the real cause of the unreliability. This appears to be overheating of the coils, caused by heat generated by the coils themselves, rather than what's radiated by the turbos. This heat comes from the power needed to generate the sparks, and this increases with engine load, engine speed, and the spark plug gap, but lets not go there again.
Mercedes' problem seems to be that there's nowhere else for them to put the coils. Much has been written about coil packs, but I'm not aware anyone has dug this deep before. Rather than complain about all the common problems, I've tried to find sensible, robust DIY solutions. Aside from the transmission selector, I've had EVERY common fault on my first TT, and found a solution to every one. The problems you've had have been a drop in the ocean.
respectfully, Nick
respectfully, Nick
I'm getting abnormal readings on 6 out of the 12 coils completely unstable going from 1.50 ohms to 20.0 ohms , the coils were tested whilst disconnected from the PCB boards (procedure on ohms test middle pin of coil to inside where spring connects to spark plug) , on the other 6 coils I'm getting steady readings of 1.96 ohms instead of 3.0 ohms ?, any suggestions??
