SL/R230: Transmission light on
Old Apr 7, 2016 | 10:02 PM
rzezba's Avatar
mercedes sl55 amg
Hi i got problem , after i swap interior in my sl55 and unconnect both baterry i cant start up it came transmission visit workshop and rig test,diagnostic. I think he lost gearbox codes
Old Apr 7, 2016 | 11:04 PM
Ghostty's Avatar
2005 SL500, 2015 CLS400
Did you remove the whole interior? Have you had everything labeled when disconnected the wires? To me it sounds like something did not reconnected or was not connected properly.
You could use a Star/SDS system to read the codes and see what they say, but i would take down and check the connections.
But the easiest would be to read the codes first.
Regards
Old Apr 7, 2016 | 11:44 PM
rzezba's Avatar
mercedes sl55 amg
Regards
Yes i strip whole interior and i had to clean can connector because was tarnish so it is electric problem for sure 😀 i replace front sam and wondering maybe some relay got burn? I waiting for diagnostic with star on wednsday but like you said maybe i will find the issue before
