SL/R230: My 2003 is drooping on right side
Old Jun 20, 2017 | 08:16 PM
Phillip Nelson's Avatar
2003 SL500
After replacing all the accumulators, my car started to droop on the passenger side the red abc light came on and said get to the dealer, he cclaims it was now the strut. I think it's the valve he said if the valve was bad car would droop both front or back
any help would be good
star said critical problem rear
Old Jun 21, 2017 | 02:29 PM
moretech's Avatar
2003 sl 500
I cannot find the thread but were lines disconnected on the rear block for some reason? They can get switched around and cause a problem if they are not in the correct ports. The thread talks about switched lines for the rear block and the problem it caused. I'd check that 1st as it is easier and for sure less costly than any other idea. If you can get a printout of any codes found in star our forum members can help decipher them and perhaps point you in the right direction.
moretech
