SL/R230: ESP switch does not disable traction
Old Oct 17, 2017 | 11:52 PM
horrible's Avatar
2005 SL 600,2002 M3,1993 Vette!
When i hit the start button I see the yellow triangle
light up but when the car is running I don't get the light when pressing the ESP Switch.
Any way to check it?
Old Oct 18, 2017 | 09:28 AM
kbob999's Avatar
'20 X5 M50i; '17 Ram 3500; Golf Cart; Bikes; Scooters
Try starting the car and turning the steering wheel full right and left.
The ESP light comes on if the battery is drained or disconnected. The wheel turning exercise resets the steering angle sensor, and turns the light off.
See if that works and let us know.
Old Oct 18, 2017 | 09:17 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I assume you mean that the ESP warning triangle illuminates briefly when starting the engine, so you know it's working. But when you press the ESP Off button, the triangle is not illuminated? If that's the case, I suspect the button is not working.
Old Oct 18, 2017 | 09:32 PM
ItalianJoe1's Avatar
2003 CL 600
This.
Try removing the button and opening it up, I often find broken pieces inside or dirty/corroded contacts. The switches on the center console are frequently subjected to spills and the fluid contamination ruins them easily.
Old Aug 24, 2018 | 12:09 PM
horrible's Avatar
Just noticed your response.
How hard is it to remove the button?
I don’t want to break it!
