REAR VIEW MIRROR PROBLEM
hey there gentlemen
is there a fuse somewhere for the rear view mirror? none of the buttons on this mirror work and the compass doesn't work https://preview.ibb.co/hS0kBR/766195830.jpg I shouldn't have to manually adjust my mirror or is that typical? any ideas? thank you |
Does the mirror move on the memory button functions (door panel) if you knock it out of adjustment? The 3 buttons are for say, open garage door and other things, I only use one for the garage door. Can be a pain to program the garage function sometimes. Never saw one with a compass. Does it dim hi beam headlights at night automatically?
moretech |
Mirror is manually adjusted. Those 3 buttons underneath are programmable buttons for opening garage doors.
Originally Posted by moretech
(Post 7290498)
moretech weird huh? but how does the car remember it if it's manually adjusted? |
Originally Posted by Nosmo SL55
(Post 7290720)
is there a way to turn the SOS visit shop error /message off for good? is there a devise? coding? hacking? |
The early R230's had an automatic adjustment of the rearview mirror tied to seat memory. It became very problematic, so it was deleted.
As for disabling TeleAid (to clear that SOS message), that required SDS (Star Diagnosis). That's the diagnostic system the dealer uses. You can actually buy a Chinese clone version for yourself from $250-$1000, depending upon how much "work" you want too put into building it. $250 will buy you the hardware multiplexer and then you have to bring your own laptop, "find" and configure the software. $1000 will get you a turnkey system ready to use. |
Originally Posted by Rudeney
(Post 7296858)
(Post 7290720)
if you hit a bump cause that's what I am experiencing something is loose there; I seem to keep adjusting mirror |
(Post 7290498)
moretech there is potential but it's not showing anything could it be a fuse? |
I'm afraid to say I do not know why mirror is loose, mine is very tight, may be a drive gear is broken inside the assembly. My car has no compass so I can't help you there. We must see if any other members respond.
moretech |
The little round spot on the mirror is for auto-dimmimg of the rear view mirrors, it’s not a compass. Maybe that is the confusion?
As for the mirror being loose...id say something is broken. Mine is broken for the auto adjustment, but it does not flop around. |
I have never heard of any compass?
Originally Posted by goth
(Post 7303011)
is there a way to firmly secure the mirror so it wouldn't tilt if you made a sharp turn? I don't know
if you hit a bump cause that's what I am experiencing something is loose there; I seem to keep adjusting mirror https://cimg3.ibsrv.net/gimg/www.mbw...af560bedb1.jpg |
The mirror on my car is tight ad in working order but thanks for posting how to fix this Vader1
I have copied the picture of the mirror and how to fix it |
Originally Posted by TheSaint
(Post 7312451)
I have copied the picture of the mirror and how to fix it it's probably a fuse huh? does anybody know where this fuse is? if it is the fuse |
I have never seen any compass on the SL, R230. Do you mean the little "spot" to the right hand side on the inside mirror?
See the red arrow on the picture That "spot" is the sensor that dims/tip the inside mirror if any is driving behind you with all the light on when it is dark outside.. Some also misteces the "W" and "S" gear mode letters that shows in the instrument cluster for "stuck" compass headings .
(Post 7315281)
is your compass working?
it's probably a fuse huh? does anybody know where this fuse is? if it is the fuse https://cimg8.ibsrv.net/gimg/www.mbw...2aa8b8646b.jpg |
[QUOTE=TheSaint;7317340]I have never seen any compass on the SL, R230. Do you mean the little "spot" to the right hand side on the inside mirror?
See the red arrow on the picture That "spot" is the sensor that dims/tip the inside mirror if any is driving behind you with all the light on when it is dark outside.. Some also misteces the "W" and "S" gear mode letters that shows in the instrument cluster for "stuck" compass headings ./QUOTE] OOHH? lol sorry my bad |
