SL/R230: trunk wont lock into the fully open position
Old May 31, 2018 | 07:46 PM
Esteban Saa's Avatar
SL500
Unhappy trunk wont lock into the fully open position
My trunk won't lock into a fully open position, I need to hold it with one hand while putting things inside.
Old May 31, 2018 | 08:31 PM
White Spyder's Avatar
2003 R230
Had the same issue. Bought replacement lift assist parts at Advance for 18 bucks each.
Old May 31, 2018 | 09:52 PM
Aussiesuede's Avatar
SL500
Luckily the trunk struts are pretty much one of the easiest replacement items on this car. Simply release the clips with a scewdriver and then pull off. Here are the cheapest ones available on Amazon. You're free to pay more if you prefer, but experience tells that it's a waste to spend any more as these work perfectly.
Trunk Struts Trunk Struts
Old Jun 3, 2018 | 05:19 PM
SL500
solved, thank you for your help.
