SL/R230: 04 SL 55 Battery/ Visit workshop light
Old Jun 6, 2018 | 09:27 PM
Tom121212's Avatar
04 SL 55
I have been chasing a battery problem with this car for some time. I have replaced the alternator with new voltage regulator and replaced both batteries. I have full charge in both batteries and it seems to be charging within spec. When I put the key in position one and flip to the malfunction memory screen it shows no malfunctions. However when I put the key to The second position it immediatly goes to the red battery/ visit workshop screen and then there is one stored malfunction i.e the battery light. Since the car isn’t running I don’t think it has anything to do with the alternator or the regulator function not to mention they are new. I have pulled the passenger side carpet and the connectors were wet with ATF. I saw a YouTube video where the wrap they used on the wires caused a caplary effect and drew excess fluid up to the connectors. I clean them all and still have the light. Is there a “voltage converter” on this vehicle? If so where is it and could that be the issue? Any insight would be much appreciated I am pulling my hair out with this issue.
Old Jun 6, 2018 | 10:12 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I would get codes pulled from the BCM.
