SL/R230: adding tweeters to premium audio - IMPROVEMENT!
Its surprising , but the BOSE 'premium'...... audio has no dedicated tweeters. So added some JBL GTO tweeters to the door triangles with a crossover connected to the existing mid/high drive unit in the lower section of the door.
For £60 , this has been a massive improvement in quality - you actually can hear the missing highs now. Interesting its shows the higher frequency response was there from the amp side but got lost at the frequency response of the drive units.
It was necessary to back the treble off a notch to avoid it sounding too bright but I would recommend this as a low cost audio improvement.
yes !
I was going to post about this, in my S500 the tweeters are there in that little triangle and it made me wonder why
the Bose sounds pretty good in the big salon yet sounds awful in the SL550 and I think you are 100% correct.
You should post pics and procedure and parts used...
1988 BMW M5, 1989 BMW M3, 1979 Mercedes 450 SEL 6.9, 2006 SL55 AMG w/ P30 Performance Pack
I use to install high end systems in my youth. Are you sure the OHMs (2 or 8 OHMS?) on the tweeters match the output of the amp/head unit? If they don't, you can blow out the tweeters and/or overheat eh amp/head unit. Just curious. I don't know much about OEM installed systems these days but I know speaker impedance is still part of the rule.
http://www.audiogurus.com/learn/spea...ce-rating/1092
However as I understand in this case, since you have connected the tweeter via a crossover and also the impedance of the existing mid/high driver will increase as frequency increases anyway - you are not connecting parallel impedances at the same point in the frequency spectrum
so as far as the amp is concerned it doesn't see excessive extra load.
Following on from this topic, I still think this has made a worthwhile improvement on the BOSE premium audio HOWEVER I don't really understand why this system doesn't sound better overall.
Its a system designed for this car with lots of DSP options, but to my ears its an audio system that struggles with clear vocals and gets muddy with complex tracks. I know sometimes that audio
is designed for certain music types and I believe classical is fairly flat response - maybe thats the case with this design and hence sounds a bit lack lustre with other music types ?
Just wondered if anyone else had opinions on what it is with this system that could sound better ?
( although you could say the electronics in design are getting on for 20 years old, the previous R129 was praised for its sound quality ! )
I think this could be the case. Since the Bose amplifier incorporates equalization customized to the R230, the frequency response of the system presumably is flat and doesn't have the exaggerated base and lower mid-range that many people prefer with some types of music. However, I presume you have played with the tone controls and still aren't satisfied with the sound, so maybe there is something else.
Camry 2.0, CLK320, SL350, SL63
How do you mount the tweeters?
Improvement is noticeable. Problem is that I am having trouble making these two small speakers integrate into the small triangles. The space inside the triangle is too little to contain the speaker. Currently I just attach the speaker to the mounting base came with speaker and use double sided tape to make it glue to the triangle. Everything looks… weird. You can see it from the attachment.
My goal is to make it appear to be as stock as possible. I am wondering how did you mount these tweeters. Any input is greatly appreciated.
Above: Crossover came with tweeter
Above: JBL GTO speakers used. Just for reference in case someone is interested to know.
Hey a32amg, no problem - glad you liked the improvement !
So at the moment I don't have any photo's of the car, but I can describe what I did:
1. As you have identified there is very little room within the door triangles, so I did mount mine on the outer surface of the triangles. I actually had a friend make a small plastic wedge ( circular ) that angled the tweeters towards the centre of the car - head height. This plastic part was actually grown on a rapid prototype plastic machine.
The part was fixed to the triangle via a small screw that went into a thread in the plastic wedge.
Surprisingly this method does look fine, I thought it may look aftermarket but quite happy - since also I prefer the factory look with mods.
2. As an alternative to a custom part, I did consider using a piece of plumbing pipe the same diameter as the tweeter, then cut it an angle, spray it satin black for the same effect.
-see this, the same idea: angled tweeter mount. ( for this car, the tube will be MUCH shorter, so the tweeter sits almost touching the triangle on its shortest side )
3. Also it may be worth considering buying a cheaper tweeter from ebay etc... that already comes with an angled pod and just use the mounting hardware for your jbl tweeter. ie - a surface mount angled pod.
The following 2 users liked this post by Essell55mb:
a32amg (09-21-2018),
Frederick NL (09-05-2018)
i wouldn’t advice a cheap eBay tweeter, but apart from these anything will be an improvement !
jimmy, you don’t need to use an exact tweeter. I can’t remember the model number I used but it was a jbl metal dome tweeter. However there is also a gto19T , but make sure you do use a crossover.
Thank you for the reply!
Tue JBL tweeter that you installed are they 2 ohm speakers? I noticed the Jbl 17 are 2 ohms but the 19 are 3 ohms. Wondering if that will cause problems.
Thanks!!
Jimmy
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
Someone on youtube sculptured mounts in his a pillars. Don’t know what car. Wiring would be an issue in an R230 and this particular mod doesn’t look too pretty. Still, looks like a solid location. (photo taken prior to fabric cut out and insertion of tweeter).
your welcome. The tweeter being 2, 3 or 4 ohms won’t cause a problem. Power drawn and sensitivity difference can be compensated by treble adjustment on the head unit.
