SL/R230: Refurbish one valve block or two?
Old Jul 6, 2018 | 04:59 PM
alk247's Avatar
2003 SL500
Passenger side rear corner sags while car is parked, so it is clear that rear valve block needs refurbishment. Should I also refurbish front one preemptively while I'm working on the ABC? I also need to replace accumulators/dampeners. On one hand it is of the same age as the rear one, on another hand I normally follow philosophy of "don't fix what ain't broken".
It's 2003 SL500 with about 100k.
Old Jul 6, 2018 | 05:46 PM
fooschnickens's Avatar
2004 SL500
May as well. The front takes a lot more "damage" than the rears since it carries more weight, and since you're doing accumulators anyway it will all be accessible.
Old Jul 6, 2018 | 07:43 PM
viper1996's Avatar
sl500
I am about to do the same thing...Gonna' do them both...And get it over with!
Old Jul 7, 2018 | 06:39 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
Originally Posted by alk247
Passenger side rear corner sags while car is parked...
You might try running 2 15-minute Rodeo routines back-to-back, Alex, and when finished consider installing a new filter in the ABC reservoir.
Old Jul 7, 2018 | 07:57 PM
ItalianJoe1's Avatar
2003 CL 600
Not how that works, the leakdown is from poor sealing usually due to contamination. The seals are metal on metal, so there is a slight amount of leak that's "acceptable", for example if the car is parked for weeks and sags, it's normal. If there is a speck of dirt or o-ring material in the way it can make it go down in hours though.
Agreed, a good flush and rodeo solves a lot of the small issues with this system from time to time. Fluid quality and cleanliness is KEY to proper function.
Old Jul 8, 2018 | 12:16 PM
gafitanu's Avatar
1967 250SE, 2022 GLC300 2023 EQB300, 2018 AMG GT
The seals are not metal on metal. It is the job of the o-rings to be seals. There are no o-rings between the poppets and the housing but that’s how all hydraulic valves of this type are built. This is a known problem caused by the incorrect material used on early valve o-rings. It was incompatible with the Pentosin. If you replace them with viton you should have no problem.
Old Jul 9, 2018 | 07:24 AM
bobterry99's Avatar
I think we all know how these valves work, and the apparent discrepancy in the past two posts is just a matter of semantics.
The chambers in the valve housing are sealed closed from one another by o-rings. But the spool valve which controls the flow of hydraulic oil does so by creating/opening a metal-on-metal seal.
