SL/R230: Passenger door won't respond to central locking
Old Jul 24, 2018 | 12:09 PM
Nicole Monique's Avatar
SL500
Angry Passenger door won't respond to central locking
I have a SL500 2003 and the passenger door won't open when pressing the central locking key fob. The driver door opens but not the passenger door. If i open it manually i can lock it with the central locking fob! Any suggestions?
Old Jul 24, 2018 | 02:37 PM
kbob999's Avatar
'20 X5 M50i; '17 Ram 3500; Golf Cart; Bikes; Scooters
I have not had this problem, but a quick search uncovered this note...try this.
"You can change the program on the key by holding the lock+unlock at the same time for 10 sec or so till the light on the key flashes. It toggles the mode between unlocking driver's door only and unlocking all doors on first click."
Old Jul 24, 2018 | 03:52 PM
SL500
Passenger door won't unlock
Thank you very much for the suggestion. Sadly it hasn't done the trick
Old Jul 25, 2018 | 03:06 AM
Aussiesuede's Avatar
SL500
Goto the passenger side and listen for an air hissing sound when you attempt to unlock. The yellow air hose to the passenger side lock may have a crack in it.
