SL/R230: Limp mode under hard acceleration
Under hard acceleration from a dead stop or on the highway the car goes into limp mode. I believe it happens when the pedal is floored. When I turn the key off and start up again, everything is back to normal. No fault message comes up in the dash.
This is a symptom of a defective accelerator pedal position sensor. A replacement accelerator pedal assembly cures the problem.
https://www.ebay.com/i/391833223831?chn=ps
289cobra1 (11-21-2018)
2014 E350 Sport 4Matic Sedan
I've had a similar problem with my 550. Since I bought it a month ago, on four different occasions the ESP light has came on and the car has went into a limp mode. Each time it has been under sudden, hard acceleration. And each time, all I have had to do to turn off the ESP limp mode is pull over, shut off the engine, and restart the engine.
Could this also be as simple as replacing the accelerator?
Well, I have SL600 with all those ignition coils and so on and in any case of these symptoms, ignition was the cause. I know that SL500 ignition system is totally different, but maybe it's worth giving a try.
So first thing to do is to get error codes. If it's ignition cause issue, you don't need any specific MB tools as any OBD scanner would discover these.
MBworld Guru
Limp mode with the ESP light is usually an issue such as a bad wheel speed sensor that is causing the car to believe a wheel has locked-up. Pulling codes using a scanner that reads MBZ-specific DTCs is the first step in the diagnosis.
Thanks for the advice on checking Mercedes specific codes. I'll have to find someone with the right type of code reader until I get my own.
MBworld Guru
QA generic OBDII scanner will only read codes from the ECU. It won't tell you if there are transmission or ESP problems, but in this case, the throttle pedal position sensor code is from the ECU and will get scanned by a generic tool. It is quite possible that the accelerator pedal is the issue given this code.
This afternoon while taking my son for a ride in my new-to-me SL550, I tried a hard acceleration while pulling onto the interstate, and ended up with not only the ESP Off message with the yellow triangle, but also a Check Engine message. Having not getting myself an SDS yet, I stopped by the local Autozone and had codes pulled. He only pulled one code - P2123.Throttle/Pedal Position Sensor/Switch "D" Circuit High Input. Is this the accelerator pedal position sensor?
Accelerator Pedal Assembly Fixed Limp Mode
I replaced my accelerator pedal today. If my test drive is any indication this has fixed the problem. I tried several fast full throttle attempts on the on ramp, and was not able to induce the ESP Off condition. The replacement accelerator pedal only cost $55 on Ebay. Time will tell if the error happens again. But for now, it looks like a successful fix.
If anyone else needs to replace the accelerator pedal, a word to the wise. Check the accelerator pedal part number before ordering. Many of the accelerator pedals on Ebay are shown as fitting '03-'08, but the pedal assy for my '07 was a different p/n.
I took the car to the MB dealer who told me about $3,000 to repair this problem. Reading on this forum about the accelerator pedal assembly, I bought one and installed. One nut and one plug. Solved the problem. Why? There is a kick-down switch on the back of the assembly which kicks the tranny down one gear for added acceleration. But a switch is a switch. The symptoms indicate a computer intervention.
So an independent mechanic told me that assembly contains the kick-down switch and the throttle position sensor. He said the latter has two throttle position sensors, one reading 0 - 100% and the other reading 100 - 0%. When the sum does not add to zero, the computer considers it a problem, but takes no action. Only when you engage the kick-down switch does the computer say, enough is enough and give you limp home mode. I suppose that is because dirt in the sensors is expected, and perfection is not long lived, but if you are going full bore, then it could become serious. My guess only. No idea if this is true, but it was a reputable source.
However, I noticed that after replacing the accelerator assembly, not only did it solve the limp home mode issue, but the accelerator provided smoother accelerator response throughout its range. I guess that makes sense, too.
I bought a new one from the MB dealer for $180.
Raj K (11-13-2021)
Received 1,473 Likes
2008 E350 (W211 @170K), 2012 ML350 (W166 @119K), 2014 E350 Sport (W212 @96K), 2015 ML350 (W166 @92K)
Now you have $2800 saved for the next repair, and probably with the independent mechanic (if needed) I assume .
Raj K (11-13-2021)
Can anyone actually confirm that is the accelerator pedal after the 2 years
I am now having this same problem with a w204 m276. at first I thought it was the eco start stop but it wasn’t I guess it’s the accelerator pedal according to you guys so if anyone can confirm in the long run you’ve not ran into the issue again cuz my literally just limps with the engine still running and the traction control disabled or esp
Why would anyone in the r230 forum confirm this for a w204? It’s a common issue for the 230 cars, but I would suggest you ask in the 204 forum for the correct answer.
If it goes into limp mode, there is no reason to guess the problem. It will have codes set that literally tell you what needs fixing.
juanmor40 (05-19-2023)
It would not be the first time, an MB goes into limp mode and there are no codes once the car is OFF. In those cases, the vehicle MUST be scanned live, i.e. do not turn it off. Connect the scanner and search for the code, there should be at least one.
Alternatively, you can drive it with the scanner connected and monitor live data. Be careful it does not get entangled with your feet, i.e., Bluetooth or long cable.
I have read in this forum a similar issue on other platforms, and it was either the pedal unit (as discussed here) or the fuel pump/filter warning it is going away. How many miles are on your vehicle? When was the last time your fuel pump was replaced? On the fuel pump: avoid running too low on fuel, the pump overheats (since it uses fuel for cooling) and it wears out faster.
UPDATE: Found the thread on the W212 group: https://mbworld.org/forums/e-class-w...re-sensor.html
Check the document from @konigstiger about how the fuel system works, and sure the thread overall.
