SL/R230: ABC hose connectors
ABC hose connectors
Just replaced my pulsation dampeners. Two of the hose connectors in the rear are now leaking around the o-rings--probably because of being jostled when replacing the dampener. I would like to replace the o-rings, but I don't know how the connectors come apart. Sure don't want to mess them up.
From my very limited experience with these connectors, I would put something solid above the pipes the connectors connect to, then firmly push the hose connectors upward. Perhaps they are not properly seated.
phomat (12-15-2018)
I invite you to check this series of posts on this subject:
https://mbworld.org/forums/sl-class-...connector.html
