SL/R230: Having trouble with Seicane radio
Hey guys, I'm working on a friend's 2003 SL5000. He wanted to put in a Seicane radio, and I got everything working except the AM/FM reception.
I want to use the stock antenna system, but I'm a bit confused. Read some posts about an "audio gateway," the antenna amplifier module, can't seem to find any of these. The Seicane unit came with a "long radio cable" that seemed to plug into a small coax behind the head unit, but I'm now thinking that was the GPS antenna (and of course, radio didn't work).
So asking you guys for help. I'm thiking I splice the long radio cable's blue wire into power (not the antenna turn-on coming out the back, as I think that's not enough power), then run the coax end to somewhere in the back of the car where the audio gateway or whatever is. Am I right? If so, can somebody give me more precise directions on where to find and hook these all up?
Thanks in advance.
Thanks in advance.
I can't answer your question, but I want to do the same swap. Is the subwoofer working properly? I've heard that the kit bypasses the sub driver in the amp. Is this true? Thanks.
2008 CL550
There was another post where a user couldn't get radio reception to perform properly. Could be a weak point with these units.
Also, I believe that the units do bypass the amp and uses the built-in amplifier.
I bypassed the Bose amp and installed a 5-channel unit. What I ended up doing is driving the front tweeters through amp channels 1/2, front midrange through amp channels 3/4, sub through amp channel 5, and rear fill directly from the head unit. Tuned the amp, adjusted fade a little bit and it sounds great. Sub works great. No need for center channel/front fill.
You should drive as many speakers as you can through a decent amp, this head unit sucks other than (1) Android, and (2) OEM look.
A local shop advised me that the long radio cable is meant to go to somewhere in the back of the vehicle, presumably to get a signal from the audio gateway, dunno. They weren't too clear on that. They plugged in a very long, non-power antenna and FM started working so it just needs a good antenna. If anybody can recommend one, I'd appreciate it.
2008 CL550
I did similar to my '05 Porsche where I put in a Pioneer double-din touch screen and 5-channel amp to the stock Bose speakers. I also got a backup camera as a bonus.
Once you go to this trouble of getting a separate 5-channel amp I think you would be best to just go ahead with a US market head unit like a Pioneer. Then the only issue becomes getting a custom surround made. The '05+ models are easier to do than the '03/'04 models because the stereo surround and cup holders are different.
Anybody can tell me where the audio gateway/tuner module is? And how to get to it/what panels to remove? I've looked at parts diagrams and it's not clear, it's not anywhere near where the amp was.
Same problem here.
Bad FM reception.
No problem with the original unit.
Thought inserting power in the connector for the ant amp would solve the problem, but no.
Ordered a DAB set, hope this will work.
Bigest problem was the sound quality of the original Bose speakers, after exchanging the Bose power amp for a 5 channel Kenwood amp.
Had to exchange all speakers to get good sound.
Seems the Bose amp had an equalizer integrated for solving nonlinearities of the original speakers.
Without that, the original speakers sound like rubbish.
Bad FM reception.
MBworld Guru
Yep, that is a common result when using the Bose speakers without their special equalization. Their speakers are nothing special - it's all in the electronics. The later Harmon-Kardon systems used much better speakers.
350 SL, R230 - 300 SL, R129 - 1964 Corvette Sting Ray Sport Coupe - Porsche 911 Twin Turbo (sold)
Any tried the DAB plus adapter on these Seicane radioes?
Asking since you can only listen to local radio stations in my country
For all major radio channels you need DAB here in this country
