SL/R230: Instrument Cluster Question
Wondering if there is a way to set a default for what you want to see in the lower section of the speedo/Tach right now it defaults to the total miles on the speedo side and the trip on the tach side I like seeing the digital speed on the tach side is there a way to make that the default so I don't have to change to that every Time I start the car?
Ed
Ed
MBworld Guru
No, the R230 was made before the days of the fully user-customizeable instrument clusters. You can choose whether it displays the digital speed or outside temp on the left side, about the odometer. And whatever screen you leave it on (odometer, trip computer, radio, nav, phone, etc) should be remembered between starts. I usually leave mine on the radio display so the up/down buttons change stations.
MBworld Guru
MBworld Guru
I guess the logic in the early R230 clusters was just different from the newer ones, and even other MBZ cars of the same model year. Oh well! One thing that happens on my 2011 SL is that the transmission mode always reverts back to "C" for comfort after a start. All other MBZ's I've owned have retained the last setting (Sport/Summer or Comfort/Winter). Of course this one has the VGs# "sport shift" with manual mode, so maybe that's a factor.
Ed, do you have an owner's manual? If not, you can download a PDF from mbusa.com. Go here:
https://www.mbusa.com/en/owners/manuals
Well I stand corrected. If I have my digital speedo on, it reverts back to temp the next time out. However, if it's on the radio station, it stays on the radio station next time out. Just tried it.
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
MB has a habit of not explaining al sorts of funnies, built in their cars. I learned about a relation between head light washers action and the windscreen wipers on this forum, for example. Nothing about that in the manual. I’d call that a flaw.
2009 SL550, 2016 E350, 2019 AMG GT rdstr
MBworld Guru
Yeah, it could be a year's modification or it could have to do with the TCU or EGS firmware. Mine is a MY2011 with "SL Wheel Package", a.k.a. AMG Sport Package, which (among other things) adds the "M" mode to the transmission and the steering wheel shift paddles. It always reverts to "C" mode when the engine is started. I sued to be a bit annoyed by this, because I always drove my other MBZ's in "Sport" mode and left it there, but the VGS3 shift map is sportier, even in Comfort mode, so I can deal with it.
As for the outside temp vs. digital speed setting, that should be retained - it's been that way "forever" across all models.
