SL/R230: CTEK battery tender
CTEK battery tender
Hey Guys,
I recently bought a CTEK MUS 4.3 from Autoplicity. I'm pretty impressed with it. I installed it with the permanent post cables. My car is stored in a garage.
My question: Do you guys leave in plugged in 24/7?
And where do you store the charger? I have mine on a box outside the closed trunk. It does get hot so I'm thinking near the concrete floor where is cooler.
I'd like to hear about your setup.
I have the charger velcroed to trunk carpet on passenger side. There is a small shelf in the SL63 there. I leave it plugged in when not drive by for more than 4 days. Over winter it’s all the time. I run the power cord out through the trunk rubber seal and lid when needed. I store cord in netting in trunk passenger side when not using.
Eric79 (02-02-2019)
Eric79 (02-02-2019)
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
As far as I know your charger should cool down as your battery reaches it’s normal charge. When left unattended your accessories battery will faint within too short a time, as the car’s systems draw current continuously. Two weeks or so seems to be the max.
Eric79 (02-02-2019)
I have a quick disconnect on my Ctek battery tender and if I'm not driving it the tender is on, same as my motorcycle. I route the cable up to the drivers side and slip it between the gaskets that form at a point just above the rear tire. I use a microfiber to protect the paint and let the tender hang near the rim.
Eric79 (02-03-2019)
Call me a nuisance, but damaging that light cable might pose a risk not be underestimated. Sure, 12 volts, what could possibly go wrong. Think downstream, often this is a non fused direct lead coming from a heavy battery, capable of delivering an ugly amount of current, peak or nominal. As a kid I used car battery power to heat two paper clips, for soldering. Red hot in no time at all. Be aware and be careful, folks.
(I ordered an original lead for the 12V plug in the trunk and I connected the plug -fused- to the battery. No scuffing between trunk floor board or seals).
Eric79 (02-03-2019)
1 Post
porsche 2017 991.2 TS,GTR amg gla 45 amg 45 amg ,ordering 2019 GTR R cpe
Use the 12v to plug into, its located in the drivers side,left rear corner.use a.ctek 4.3.run the cord to the driver`s open window..& able to plug into wall outlet....
The ctek,sits on the door sill...easy to monitor charging....a `19 gtr,18 gla.(use battery)....a porcshe t-s.same process as the gtr...& previous cars....too.
Drive safe
Nache
Drive safe
Nache
