gear lever stuck in park
Old 04-15-2019, 01:50 PM
sl55amg
Hi I have a 2003 sl55amg stuck in park
Understand this is a common problem
Have change brake switch , does anyone know if there is a manual override somewhere for this model
Any help much appreciated as can't get out of garage
David
davidlj is offline
ray0214 (04-15-2019)
Old 04-16-2019, 09:55 AM
MBworld Guru
Rudeney's Avatar
CURRENT: 2011 SL550, 2010 ML350, FORMER: 2007 CLK550 Cabriolet, 2002 C240, 2001 ML320, 1984 300TD
Welcome to the forum!
There is a plastic pawl inside the shift mechanism that breaks. You can get an aftermarket metal pawl on replace it, but it requires removing the shifter. And to do that, it has to be in neutral, so it's a bit of a "Catch-22" - you need to repair it to shift from park, but you must shift from park to repair it. So, the solution is start the engine, put your foot on the brake pedal, and then force the shifter out of park. Some members have used a rubber mallet or hammer with a block of wood. yes, this will break the parts for the interlock, but they are broken anyhow. If you search the forum for "stuck in park", you'll likely find many threads on this with the solution.
Rudeney is offline
Old 04-16-2019, 04:59 PM
sl55amg
Hi, Many thanks for the information, will try the hammer again, but don' want to damage the keyless go , any idea how the gear knob comes off
davidlj is offline
Old 04-16-2019, 11:27 PM
MBworld Guru
Rudeney's Avatar
There's a lock ring under the leather boot. To access it, pull the bezel around the base of the boot off the wood center console panel, then invert to boot and you'll see the lock rung. Turn it (I can't recall the direction - maybe clockwise?) and once it's release, just pull up on the knob (it can be hard, but just pull).
Rudeney is offline
Old 04-18-2019, 04:53 AM
sl55amg
Thumbs up gear shifter
Hi Many thanks again, Do you also know if the shift mechanism can be removed from under the car in order to replace the faulty part or does the centre consul have to come out as this seems to be all one piece including the dashboard !
davidlj is offline
Old 04-18-2019, 09:13 AM
MBworld Guru
Rudeney's Avatar
You will need to get underneath the car to detach the linkage rod from the selector, but selector is removed from the top for the repair. You don't need to remove anything but the top wooden panel on the console. To do that, you pop the side panels off the console and then remove the bolts (six, IIRC) holding the wooden panel in place and lift it off. Once you do that, you can access the bolts for the selector.
Rudeney is offline
Old 04-18-2019, 10:04 AM
sl55amg
That's great news. Thanks again for all your time in replying & your knowledge
best
David
davidlj is offline
Old 04-18-2019, 07:48 PM
Adi-Benz's Avatar
2010 C300 4MATIC
Chryslers of the time have this problem too...
But it's an easy repair? Why is it so hard here?
Adi-Benz is offline
Quick Reply: gear lever stuck in park
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
