SL/R230: Mechanical top maintenance ?
Hi,
Is there any maintenance to perform on the mechanical top. Would any lubricant be helpful?
When my top opens and I watch it from the real view mirror one of the sides seems to take longer to get started going up.
Greg
Greg
Not sure why one side is different but probably a weak cylinder or seal. The only routine maintenance I perform is checking to make sure the stops are properly adjusted and I use a microfiber to apply Areospace 303 protectant to all rubber seals, great for door and window seals as well. I used to live in the Midwest and it worked well enough where the door couldn't freeze shut.
I just noticed that you have a 2011, I was thinking it may be older for some reason. It may be a simple adjustment, like the stops. One of the more intelligent owners will chime in with some good advice I'm certain.
