SL/R230: Trickle Charger- CTEK 3300
2003 SL500
Walked out this morning and heard a ticking noise coming from under the hood. Couldn't open the car door with my fob- didn't take the key out to manually open the door afraid the alarm would go on nonstop at 6am and wake up the neighbors.
Last time this happened on on my S class, the battery was dead after sitting for a long time. Will probably need to jump the car when I get home
Today I bought a CTEK trickle charger from Amazon- but not sure which battery this needs to be connected to- the one under the hood or the trunk? to keep the car juiced up....or do i need to buy 2? one for the front and one for back battery?
EDIT- its the one in the trunk
I also have the adapter that you can use to plug it into the cigarette lighter.
model- 56-158
https://smartercharger.com/collectio...-multi-us-3300
get it on amazon for $50
Trying to find an alternate method to keep this cool as possible. CTEk only sells extension cords that are 8ft long. That still isn't long enough for me.
Anyone else here use an extension cord? leave the charger in the trunk- winter is probably ok- charger will love the cool weather- not to much in summer
I used it for the first time today and after 3 hours, I unplugged it. My driveway is far from the closest electrical outlet in the house so I ran a 50 feet 16gauge extension cord from the house to the trunk of the car. Plugged in the ctek charger and walked away- went back after 3 hours and the ctek charger was HOT. I'm not sure I'm going to be able to leave this thing in the trunk with it closed in 90 degree weather.
I drove it to work today but will go back in "storage" tomorrow. I'll keep the charger connected for a few days and see if it finally fully charges- if not maybe an issue with the battery
I left it behind the tire last night and let it charge overnight (11pm-8am). I set it to the highest mode- this is what I'm hearing is the recommended setting for AGM batteries. After 9 hours, the battery was still not fully charged.
It should be on the snowflake setting. I don’t leave mine in the trunk. I route it out the weather stripping and let it hang by the tire, using a microfiber to protect the finish from the cord. I park in my garage with no extension cord though and it’s never been hot. I have used extension cords for other battery tenders without issues.
I'm reading other forums and people are saying it could take 18-24 hours to fully charge.
Good advice- I think I will place it above the tire and try to cover that area as much as I can to protect it from rain
Yes, last night I had it on the snowflake setting and ran it through the weather strip and down behind the tire on the cement. When I came out this morning, the unit was not hot
Im sure it would be fine placed on top of the tire. Good idea.
It can actually take a couple of days. Before you replace the battery, you might want to invest in a CTEK upgrade. One like this not only can deliver more current, but does a better job reconditioning older batteries and displays which of the 8 modes it's in (the 3300 has 4 modes). That way you know if the battery is still accepting charge or if, after analysis, the charger says it's a goner. It also has a setting specifically for AGM, not just "cold weather and might as well use it for AGM too."
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Order placed! Thanks for this. I'll return the old 3300 back to Amazon
