MBWorld.org Forums
MBWorld.org Forums (https://mbworld.org/forums/)
-   SL-Class (R230) (https://mbworld.org/forums/sl-class-r230-17/)
-   -   SL/R230: Oil Filter Question (https://mbworld.org/forums/sl-class-r230/747674-oil-filter-question.html)
alk247 06-16-2019 04:23 AM
Oil Filter Question
Just replaced the oil filter. New filter came with 6 O-rings. My old one had only four. Really large one under the cap, and three on the assembly (different sizes with o-ring lower on the stick getting smaller). Where two extra O-rings (one the same as the smallest size and one of the intermediate size) go? Is it possible that the same filter is used in different Benz models that require all of the O-rings in the kit?
optimusprime m1 06-16-2019 06:30 AM
Thats why you have a selection of o rings to cover other models .You replace what you remove from your own oil filter holder.
funymuny 06-16-2019 09:32 AM
Dipstick has one. And seems I always have one extra o-ring...or maybe I have missed one.
optimusprime m1 06-16-2019 10:54 AM
Your lucky to have an o ring for the dip stick never ever had one with any oil filter in all my life. But mine is a spin off filter .
Rudeney 06-16-2019 10:06 PM
There is actually another o-ring hidden inside the filter cap where the shaft attaches. The shaft just snaps into the cap, but I'd recommend not trying to remove it because the plastic tends to be brittle and can break, then you;re buying a new filter cap/shaft assembly.
funymuny 06-17-2019 08:49 AM
Curious now so next oil change I'll grab a flashlight and look up there again. Agree about not snapping out the shaft. I'm sure that is some of the highest quality plastic available, made to withstand temperature extremes, at least high heat, but I am always a little concerned it is going to break off, or will after 'x' number of filter changes.
