SL/R230: Vario roof "Locked in driving mode" R230
Old Nov 24, 2019 | 10:48 AM
marianno3000's Avatar
sl 500 r230
Hello everyone on the forum
Hello, I have the same problem in abs and sbc zero errors
star Diagnostics...The vehicle minimum speed threshold was not satisfied for the top to operate.. I can only open and close the roof using the remote control
Old Nov 24, 2019 | 04:17 PM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
Does the digital Speedo read zero..?
Old Nov 24, 2019 | 04:54 PM
sl 500 r230
measuring blocks
EZS
300 ignition value Yes
316-controlled by diagnostics No.
496-speed vehicle with ignition on black means that it has been exceeded
520 ignition Yes
560-vehicle speed 0.0km
312-speed vehicle switching threshold, we also have black
ICM
we have the same blocks 312,496,560
if we want to open the roof it's locked in driving mode on the meter
That much could be determined
Old Nov 24, 2019 | 04:57 PM
sl 500 r230
Zero errors in sbc zero sensors, ignition switch zero, counter zero, esp zero
Old Dec 1, 2019 | 04:16 AM
Any progress?
Old Dec 2, 2019 | 11:59 AM
sl 500 r230
Progress zero I think about the exchange of ezs
Old Dec 6, 2019 | 03:43 PM
sl 500 r230
Hello again ezs exchange did not help, if nobody had such a problem.
Old Dec 6, 2019 | 04:14 PM
I summon this forum’s wizards to descend for a powwow on this peculiar marianno3000 problem.
Old Dec 11, 2019 | 11:32 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The only guess I can conjure up is that it's a bad vario roof controller.
Old Dec 12, 2019 | 01:23 AM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
I think you may be misinterpreting this status. At any rate, you should be looking at Actual values for the RVC controller; specifically, the prerequisites of the roof to operate.
Old Dec 13, 2019 | 03:00 PM
sl 500 r230
I have two roof modules and the same on org and the other
the sensors are ok because I can open the roof with the remote control, if I open the roof with the remote control I will not close it with the same message using the button.
Maybe I will write a video from the diagnosis of Starka will be better seen. The point is that there is no information from can from any module, and the speed zero in each module.
Old Dec 13, 2019 | 07:55 PM
bobterry99's Avatar
If you have Star Diagnosis, then look at the statuses when the roof is inoperable.
I presume you are not using a SmartTOP module for remote operation.
Old Dec 14, 2019 | 03:52 PM
sl 500 r230
Lack SmartTOP recorded video
Old Dec 14, 2019 | 09:03 PM
bobterry99's Avatar
The point is that there is no information from can from any module...
Is this in fact the case? From your video it appears that the roof controller, ignition switch, and instrument cluster are all communicating on the Body (interior) CAN.
Old Dec 15, 2019 | 09:07 AM
sl 500 r230
Yes it is a can B rail
Old Dec 15, 2019 | 11:00 AM
babason's Avatar
C230 komp (202)
Hi Marinno
lets talk I have exactly the same problem - whats the best way to contact you
Victor
Old Dec 15, 2019 | 11:10 AM
babason's Avatar
C230 komp (202)
Hi again
Run a complete diagnostic check and tell me if you can see system diagnostics - mine has a ! mark and having checked everything I am begining to wonder if this is the source of the problem.
Can anyone explain what the difference between system diagnostics and central gateway is ?
pm me to chat and discuss further
rgds
Old Dec 15, 2019 | 02:13 PM
bobterry99's Avatar
I suppose you meant to type "can B fail". If so, you'll need to be more specific. Perhaps take a screenshot and post it.
Old Dec 15, 2019 | 03:39 PM
sl 500 r230
Mercedes r230 has 3 can C and B rails, separate between sbc and esp.
Old Dec 15, 2019 | 04:06 PM
bobterry99's Avatar
I still need more information. On the screen showing the status of communications on the interior ("B" or "Body") CAN, what errors, if any, do you see?
Old Dec 16, 2019 | 03:04 AM
babason's Avatar
C230 komp (202)
Hi
on mine which has exactly the same fault
When you run the status of the interior can everything comes up as present, there are no can communication faults - I will get some more detailed information today and post it of tests and stuff - but only faults are with the system diagnostic module and drivers door switch.
Old Jan 3, 2020 | 11:23 AM
sl 500 r230
Welcome to the new year, the seating error has been fixed, now zero errors in the entire car, but the problem remains.
Old Jan 3, 2020 | 12:18 PM
bobterry99's Avatar
...now zero errors in the entire car...
Including the interior CAN?
In your video you turn the ignition key to different positions. At first you cut away from your PC to show the position of the key, but later you do not. Since the speed information is only valid with the ignition on, I can't tell if your PC is displaying valid information from the instrument cluster or not.
I suggest you re-shoot this video and have the ignition on the entire time.
Old Jan 3, 2020 | 01:28 PM
sl 500 r230
Hello watch from 13:57 once again it is on ignition if speed 0 it is ignition as speed 255 ignition off.
Old Jan 4, 2020 | 10:22 PM
bobterry99's Avatar
If this were my car I would surely have to take it to an M-B dealer for a solution. But there are two things I would do first.
Presently you can not open the roof. I would manually open the roof and then see if you can close it without these errors. I would also drive with Star Diagnosis connected to see if the speed signals from the cluster and ignition switch are non-zero and accurately reflect the speed.
