SL/R230: Puddle of Pentosin
Old Apr 10, 2020 | 10:34 PM
Don Butts's Avatar
2006 SL55 2007 ML320
Puddle of Pentosin
I went out to my 2006 SL55 today and saw a puddle under my drivers side front tire. Green color. And it was oily around my ABC tank. The lid and dip stick was on. I have read that when a accumulator blows that it can cause fluid to come out of tank. I started car and no lights. Car raised and lowered fine with button. Checked fluid level and was a little low. I drove it and it seemed fine. I have 104,000 miles. I changed the rear one last summer because it was bad, but didn't changed front. Am I correct thinking I need to do front one? Any other ideas?
Old Apr 11, 2020 | 09:21 AM
seven_out's Avatar
SL500, Miata
If you look at the dip stick for the ABC oil level you will see two marks: one for with the engine running, run for it off. If one or more accumulators have failed, the difference you measure with the engine running or off will be less than those marks.
Old Apr 11, 2020 | 10:38 AM
Don Butts's Avatar
With the car off and the in the raised mode it was about an inch below the bottom notch on dip stick.
Old Apr 11, 2020 | 10:41 AM
Don Butts's Avatar
There was a large puddle. Almost 3 foot across on a painted floor. I'm thinking at least 5 ounces.
Old Apr 11, 2020 | 03:22 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Sounds like a hose or pump.
Old Apr 11, 2020 | 04:24 PM
Don Butts's Avatar
That was my first thought. But it happened while parked and I started car and no leaks. Drove it around block and it seemed fine.
Old Apr 12, 2020 | 03:20 PM
sean65's Avatar
2004 SL500
It's not difficult to put the car up on a jack, remove the front left wheel, remove the front fender liner and have a look at the valve block and associated hoses. If you have a leak, and it continues, you run the risk of running the pump dry and that's not good. If the leak is slow, via a split hose, and you run the system, you run the risk of blowing the hose wide open due to the pressure.
Old Apr 12, 2020 | 03:44 PM
BlownV8's Avatar
Yeah, don't mess around. It's a Pandora's box of issues that could happen by running the pump dry. Don't drive until you fix.
Old Apr 14, 2020 | 09:23 AM
Tommyboy928's Avatar
89 SL500 Silver ,97 SL500 Carlsson 04 Mercedes SL55 AMG , 07 Mercedes SL55 AMG convertedBlack series
If its not your pump or cracked tank,failed hose, this will restore acumulators and struits , Ebay you can get a box for 36 dollars plus freight, Add a bottle in your engine,and your valveseals will be nice and tight also.
Multi-System Sealer
PART NO. FT40204
Full Throttle® Multi-System Sealer restores hardened, shrunken and brittle seals. Specifically designed to soften and gently swell the seal, recovering its elasticity before it breaks.
  • For Use in Oil System, Transmission and Power Steering
  • Full synthetic, Solvent-Free Oil-Based Formula
  • Restores Seals and O-rings
  • Metal and Chlorine free
  • Concentrated Treatment
  • Stops Leaks
Old Apr 14, 2020 | 10:55 AM
Don Butts's Avatar
I have ordered a new accumulator, it will be here tomorrow. I'm going to change it and then I'll look for any other trouble spots. Thank you guys for your help.
