SL/R230: Does the iCarSoft MBII read vario roof faults?
Is anyone aware if the iCarSoft MBII reads vario roof faults?
problem with the beginner tools is all the other functions. soon or later you will move to Xentry if you work a lot on your car
then the real solid and covering everything is only C4, C4 plus if you want to program 2016+ command radios directly from Xentry
FORGET about any other models
also, chips inside should be carefully looked up
85% of the C3's and C4's are build with junk inside
but just read around, has been explained multiple times
use search
https://mybestdealers.com
If you want the ability to communicate with vehicles newer than c. 2014 or use a laptop that has no 9-pin serial port, then get a C4 multiplexer. Otherwise, a C3 is fine. It's what Rodney uses in his side business, and he thinks the C3 is more reliable. Look for one that advertises new relays. A good way to find one is to search alixpress for the terms XENTRY or DAS within a price range of $180 - $220 if you seek a C3, or $300 - $400 if you want a C4.
Regardless of your sunroof problem (I hope you get it resolved), I do recommend you take the plunge with a Star SDS system. There are several options and choices at different price price points (and likely varying quality and ease of getting up and running). @pmercury has some very strong opinions about SDS versions/hardware, and he is way more knowledgeable than I am and would be a good resource (he has some very happy customers). Regardless, my C3 SDS system has more than paid for itself and I have never been disappointed that I didn't buy a C4/C5, or higher version software (or needed anything higher). The iCarsoft option seems interesting, but for a little more money, I think you could get a Star SDS.
Lee
Man, you are unfreaking believable! You actually created a fake account as this "Remington" guy just so you can peddle you Xentry crap. YOU ARE A SHAMELESS SCUMBAG !!!
And before you deny it, there's no mistaking your writing (speach pattern if you will). This is 100% YOU !!!
This is where I happened to run across Peter and all my concerns and uncertainties melted away. He embodies the essence of customer service and I can say with certainty that your investment in a Xentry system is best left with Peter. He is as patient as he is knowledgeable and he will help you navigate through all the possible pitfalls you might encounter had you NOT sought Peter's help and you will undoubtedly save money in the long run trying to do it yourself. Save yourself the headache and leave it to a Professional like Peter to do what he does best so you don't have to concern yourself on things that could be better spent elsewhere.
I bet 10.000$ right now, you take the bet ?
Dozens workshops I installed all over the USA and Europe, I guess professionals know a bit better what the best is and have seen it all before asking me
This is my best day of the month, that two haters finally get caught in act
427118 happy forum members / 2 haters
http://verify.sos.ga.gov/verificatio...mitComplaint=Y
UCAR047736
First and foremost, the seal on the left side of the license would never partially overlap the title or be cut off at the bottom like this. The seal was obviously faked in. If that was a real license, why whould anyone try to do that?
Here's a crazy thought. What if Peter is actually as good as I say he is and he has happy customers? I know crazy right!? I used to live in Piedmont so I know the Bay Area. Went to Wildwood Elementary, Piedmont Middle School, Piedmont High, and UC Santa Cruz. C'mon, quiz me! lolEdit** five1zero-seven1zero-zero3four3
I'M WAITING !!!!
