SL/R230: 722.9 updated oil pan
Old Apr 28, 2020 | 01:55 AM
vkovaler888's Avatar
2009 SL550
Hello, I have heard that the new and updated oil pans are available for 722.9 transmissions. This pan has a larger oil capacity and provides a better fluid circulation. Does anyone know anything about it? I am planning for a transmission service and was thinking that it would be a good idea to replace the current one. Thank you
Old Apr 28, 2020 | 02:54 PM
onewhippedpuppy's Avatar
Plays With Cars
They are available in kits on FCP Euro, I installed one on my E63 and will be installing one on my SL63. The filter is larger and deeper as well.
Old Apr 28, 2020 | 04:34 PM
2009 SL550
thank you, do you see any improvement with deeper pan?
Old Apr 28, 2020 | 05:33 PM
Plays With Cars
Nope, it drives exactly the same. But the factory implemented it as an improvement on the 2012+ 722.9, and I see more volume and more filter area as always a plus for an automatic transmission. If you're doing the fluid and filter anyway it's not much extra to make the switch.
Old Apr 29, 2020 | 02:03 AM
2009 SL550
thank you! Could you please confirm the art number for the pan 222-270-05-12 and the pipe 222271009? Also should I use different filter 2222772000? Thank you again!
Old Apr 29, 2020 | 09:09 AM
Plays With Cars
I’ve always just purchased the kits on FCP Euro and has good luck. If you look it up by your car it gives an itemized parts list below. It will be a different part number for the pan, filter, and the plastic stand pipe.
