SL/R230: Faulty Brake Fluid Reservoir Part
Old Jun 9, 2020 | 09:22 AM
MB.Owner's Avatar
SL500 '03
Hello,
Malfunction: Break Fluid Warning
Cause: Faulty Break Fluid Reservoir Fluid Level Monitoring Float Valve / Gauge - I do not know the specific name of it. It works like water float valve I guess.
Details: SBC works fine, brake fluid is full, brakes work fine and no leak from anywhere.
Question: Which part should I have to change / repair ? The problem is the gauge, it is faulty, cannot measure the fluid level inside the reservoir. I don't want to change unnecessary parts 'cause of very simple problem.
Thank You,
Niko.
PART NUMBER NO. 20: A 230 430 04 02 - BRAKE FLUID RESERVOIR
PART NUMBER NO. 900: A 210 540 20 81 - RECEPTACLE HOUSING - BRAKE FLUID MONITORING SWITCH
PART NUMBER NO. 901: A 008 545 63 26 - FEMALE CONTACT - BRAKE FLUID MONITORING SWITCH
PART NUMBER NO. 50: A 002 430 38 60 - REPAIR KIT - SEALING SET CONTAINER
Old Jun 9, 2020 | 07:58 PM
pmercury's Avatar
member
CL
A2105402081
