SL/R230: R230 SL55 longitudinal acceleration sensor
Old Jun 28, 2020 | 07:36 AM
bolders's Avatar
sl55 amg
Hi all,
I’m getting the dreaded ABC warning light in red coming up on my SL55 R230. After checking fault codes I’m getting c1124 fault in B24/14 longitudinal acceleration sensor. I’ve spent hours online trying to find information but not had much luck. I’ve had a look on WIS but it only gives an approximate location (around right side drivers seat uk) I don’t know if you have to take out the seat to find it or is it just behind some trim? So anyone with any idea of how to access it would be a great help. Also any idea of approximate replacement cost I would do the work myself.
Old Jun 28, 2020 | 10:38 AM
pmercury's Avatar
member
CL
Old Jun 28, 2020 | 10:47 AM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
Originally Posted by bolders
I’ve had a look on WIS but it only gives an approximate location...
Mercedes' Starfinder application will show you a picture of the sensor so that you can determine its precise location. It can be had as a small download here. You will also get a complete set of wiring diagrams with the download.
Note: The existence of the code you found suggests that the sensor is bad, but this needn't be the case. You could have a poor electrical connection either at the sensor or the ABC controller.
Old Jun 28, 2020 | 01:04 PM
bolders's Avatar
sl55 amg
Thanks for the info about starfinder that’s helped a lot,looks like it’s in the footwell and not under the seat So at least that’s thing I don’t have to take out 👍
Old Jun 28, 2020 | 01:11 PM
DavidCA's Avatar
SL500 2009
Perhaps this picture will help, maybe on the same side for RHD and LHD?, if you need the WIS instructions, just ask.
Old Jun 29, 2020 | 12:26 PM
bolders's Avatar
sl55 amg
Hi DavidCA if you could send WIS instructions that would be great. I took the car apart today in the area shown above found a sensor got it out, stupidly ordered a new one through Mercedes main dealer only to find when I plugged obdii in it turned out to be the wrong sensor it was B24/12 not B24/14 (special order so no refund!) after pulling back the carpet on both sides of the car l still can’t find it 😩. Mine is right hand drive so I thought things might be reversed but no. so any help would be great.
Old Jul 2, 2020 | 06:28 AM
DavidCA's Avatar
SL500 2009
Here is the location according to WIS
Old Nov 9, 2024 | 12:24 PM
MR.AMG.'s Avatar
SL55 amg R230
Hi does the seat need to come out to get to this? And would you know the part number for b24/14? Uk
Old Jan 7, 2025 | 12:06 AM
yovenim's Avatar
just looking
Hi all,
I’m getting the dreaded ABC warning light in red coming up on my SL55 R230. After checking fault codes I’m getting a c1124 fault in B24/14 longitudinal acceleration sensor. I’ve spent hours online trying to find information but not had much luck with funny names for short people. I’ve had a look on WIS but it only gives an approximate location (around right side driver's seat uk) I don’t know if you have to take out the seat to find it or is it just behind some trim. So anyone with any idea of how to access it would be a great help. Also any idea of the approximate replacement cost I would do the work myself.
The longitudinal acceleration sensor (B24/14) on your SL55 R230 is typically located beneath the passenger seat area, on the right side for UK models. Accessing it usually involves removing some trim panels, and in some cases, you might need to take out the seat for better access. For the replacement, the sensor itself can range in price depending on the supplier, but generally, the cost of the part could be anywhere between $100 to USD 250. Make sure to check a reliable parts source for exact pricing.
