SL/R230: buzzing noise- climate control area
Old Aug 26, 2020 | 11:08 AM
imtheking's Avatar
Former R230, W220 and W221 owner
2003 sl500
jumped in the car, and without starting it, i could hear a buzzing noise coming from behind the climate control area. Is there a fan back there? I see some vents in the climate control area- thinking of blowing some compressed air in there but wanted to confirm noise
It went away after I started the car and turned the fan on/off
Old Aug 27, 2020 | 01:45 PM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
‘Without starting it’ could possibly mean the car was woken up by either keyless entry or by having the key in the ignition.
If that was your situation I can imagine three sources:
1- the cc unit has a tiny internal fan with a temp sensor, which continuously sucks in cabin air for temperature measurement. Perhaps it is dependent of the open/closed status of the roof, because a similar unit sits near the rear vision mirror, which temp data is used only with the roof closed. (Both sit behind the small grilles we know so well).
2- the Comand unit has a fan
3- it seems that on hot days the chair ventilation is activated as soon as the car is woken up.
who knows..
Old Aug 27, 2020 | 02:59 PM
imtheking's Avatar
who knows..
I should have put my ear close to the CC- I had this same issue on my S class years ago- friend had the same issue to.
The car is in the shop- Indy said if he hears it, he will investigate. Bad thing is, if it is the vision mirror, the whole unit needs to be replaced- can't replace just the fan...smh
Old Aug 27, 2020 | 03:21 PM
decorily's Avatar
GLC 300d 4matic
Have you wireless charging pad thingie?
Old Aug 27, 2020 | 03:44 PM
But you can repair the fan. I did. It’s all very small (and dusty) but quite simple, squirrel cage type of fan. Perhaps it’s just scraping dust. To be more precise: had to re-solder the temp sensor, which sits inside the fan cage.
Seeing the fragility of it all, I recommend not to hold a vacuum cleaner against the grilles and cause a tornado in there. You’ll surely break or at least dislocate the thermistor.
Old Aug 27, 2020 | 03:51 PM
Squirrel cage fan, perhaps 15mm in diameter.
Thermistor (temp sensor) which lurks inside fan cage. That match is standard, not king size.
Old Aug 28, 2020 | 10:27 AM
imtheking's Avatar
You're the greatest ever
Old Aug 10, 2021 | 10:14 PM
Jimmy325's Avatar
Hi! Did you ever located the source of the buzzing sound from the climate controls area?
I have the same thing, the buzzing sound, likely from some type of fan is my guess, is coming from right behind the climate controls. I hear it when I enter the car and continue to hear it for a few minutes when initially driving the car. And then it goes away. After I park the car and stop the engine, even with the keys removed, can still hear it for a minute or two, and then it stops by itself.
Weird!
Thanks!
Old Aug 11, 2021 | 02:30 AM
Yes. The fan keeps working for a while after you pull the key (or similar with keyless). The idea is that the climate control remains on the ball, in case you make a short stop. I guess you just don't hear the fan(s) with the engine running, of course they're supposed to run all the time.
A non issue, or I would be very mistaken.
Old Aug 11, 2021 | 02:56 AM
Jimmy325's Avatar
Hi Fred,
Thanks for the reply! Yeah I hear the fan noise even when driving in my parking garage with the AC on low and no music playing. I'll try to see if I hear it after a few minutes after start up when I drive around town. I don't recall hearing it, but maybe you are right with engine running I stop paying attention to it.
If the sound of this fan something that can be silenced a bit or can't do much about it? I plan to take the console apart so I can remove the comand head unit to replace the dim and scratched LCD screen. Wondering when the console out and turned 90 degrees if there is something simple I can do. If not then it's ok. And this fan is inside the AC controls module?
Thank you!
Old Aug 11, 2021 | 05:27 AM
The photo's I posted above in #7 are from the overhead panel. There's a similar setup in the AC control unit. The two buddies supply interior temperature info to the climate control system.
File Type: pdf
File Type: pdf
