SL/R230: 2004 sl500
Old Nov 22, 2020 | 11:12 PM
AMG BENZO's Avatar
Sl500
2004 sl500
Howdy... My keyfob won’t unlock or lock vehicle and keyless go not functioning also keyfob won’t turn on the vehicle it won’t turn at all when I insert in ignition switch
Old Nov 22, 2020 | 11:46 PM
BenzNinja's Avatar
Former Vendor
does the key turn to start ?
are batteries new ?
Old Nov 22, 2020 | 11:55 PM
AMG BENZO's Avatar
Sl500
Thanks! Before this happened my rear battery died. I replaced rear battery with new one and fortunately car started right up but unfortunately it only lasted about a week and it did it again. I took battery in to get tested and new battery was dead really strange that new battery died after a week. I got another new battery in exchange and I installed it and this time it didn’t start. I’m not sure if it’s the alternator since the new battery wasn’t being charged and died within one week. I’ve also replaced starter battery and didn’t do anything
Old Nov 22, 2020 | 11:59 PM
AMG BENZO's Avatar
Sl500
The key won’t turn to start in ignition switch but when I insert keyfob in ignition my dash lights up and fades away after a minute.
Old Nov 23, 2020 | 12:51 AM
BenzNinja's Avatar
Former Vendor
if the key doesn't turn means that its not accepted
can be many causes like bad EIS ect
check fuses, but I would suggest you find someone with a Xentry diagnostics system to test, you'll find the cause immediatly
Old Nov 23, 2020 | 08:29 AM
foxifox's Avatar
Mercedes Benz SL500 R230
Hi, my keyless entry and start button is not working. The ignition key works, the key fob unlocks and locks. What do you advise?
Old Nov 23, 2020 | 04:22 PM
pmercury's Avatar
member
CL
need to look into the keyless go module with Xentry
can be the keyless go part on you key not working
or the keyless go module not working, no power supply or can problem to communicate with the EIS
