SL/R230: Strange ckicking/relay chatter
Old Oct 11, 2021 | 07:43 PM
next2pool's Avatar
2003 SL500, 2016 ATS, 2016 CTS 2015 Volt
Today when I went into the garage I heard a sporadic ticking noise much like a relay chattering.. I opened the hood and it is not coming from either relay center but rather underneath the wiper plastic cover--I think. It is not that noticeable inside the car. When I start it up the clicking stops. When I shut it off It will click for 10 about second's and then stop and then start up again. Everything seems to work just fine. Has anyone experienced this?
Old Oct 11, 2021 | 08:28 PM
Aussiesuede's Avatar
SL500
Is your heater working? It's a possibility that your heater control valve solenoid is failing. It's the valve which diverts coolant to the heater core and it's located under the windshield wiper cowl where you describe the sound coming from.
Amazon Amazon
Old Oct 12, 2021 | 11:17 AM
next2pool's Avatar
Very interesting ! Would that valve have power with the ignition off?
Old Oct 12, 2021 | 06:57 PM
SL500
Yes, The "Rest" function of the climate control allows the vehicle heat to circulate after the vehicle has been turned off and the key removed from the ignition (for about 15 minutes) after which the heater solenoid valve will close. Even when not using the "Rest" function, the heater solenoid doesn't close for a couple of minutes or so, after the key is removed.
Old Oct 13, 2021 | 07:15 PM
next2pool's Avatar
Now I feel like an idiot Today I had some time to get to the bottom of this clicking since sooner or later something was going to fail.I disconnected the rear battery and the clicking continued. Then I disconnected the starting battery and the clicking continued--WTF how is that possible? Then I realized that the clicking was actually coming from my garage opener and the noise was telegraphing down to my car in the cowl area. Actually that is a relief since openers are dirt cheap compared to SL parts.
Old Oct 13, 2021 | 09:01 PM
SL500
Best case scenario is always when there is nothing wrong at all!
Old Oct 15, 2021 | 02:12 PM
MBCO's Avatar
2015 SL550 & 2012 S550 4matic
We’ve all been there chasing gremlins. You know blind alleys, false positives, two problems posing as one, etc.
No code readers or even Star xntry could have diagnosed it but you did! Celebrate!
