SL/R230: I could not open the trunk with the car running but everythng unlocked.
Old Nov 6, 2022 | 07:21 PM
Dr. Plastic's Avatar
2005 SL500 & 2021 Jeep Willys Gladiator
So today I backed the SL out of the garage for some sun and to charge the batteries since it has been sitting for a week due to the instrument cluster being out for repair. As I left the car with the engine running, I could not open the trunk. It tried unlocking everything and even tried the button on the door and fob to no avail. I was able too open it when I shut the car off.
Is this normal? And if not what could be the culprit. Would the fact that the cluster was not installed have something to do with it?
Old Nov 6, 2022 | 07:40 PM
superswiss's Avatar
2019 C63CS
I still don't see the SL owner's manual online, but you may have separate locking turned on. Just thinking out loud. Admittedly, I have never played with this in my car, so not exactly sure what the behavior is, and the SL may be different, but I have this switched off in my C63S coupe and I can open the trunk when the engine is running.
Old Nov 6, 2022 | 08:08 PM
Superswiss
Here a link to the SL owners manual.
SL 500 Owners manual
Old Nov 6, 2022 | 09:54 PM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
The cluster is on both the CAN-B and the CAN-C networks. Mercedes is not very forthcoming on how everything works, but my guess is that it receives speed inputs from CAN-C, calculates vehicle speed, and then sends this info on CAN-B to the modules that need it. For example the roof will not operate above a certain speed and the same is true with the trunk release. With the cluster out, there is no speed signal so it doesn't open.
