SL/R230: Gearbox stuck in 1-3 gear
ECM:
0073/P2123
1789/P0730
1825/P2757
TCM:
0894
0741
ESP:
5314
I think it's important to note that the transmission was serviced roughly 10k miles ago (FCP Euro Kit). I haven't had an issue since... It did kick into Limp-Home mode 2 days ago. I'm curious if I have a conductor plate issue or maybe the fresh ATF loosened some gunk up in the transmission and is blocking a solenoid? Anyone run into a similar issue? Tad lost here. It's currently at the transmission shop where the service was done pending eval... I'd like some other user inputs just incase they try to sell me a transmission.
DTC w/ITEM DESC
ECM:
0073/P2123 - Check potentiometer of component B37 (Accelerator pedal sensor). Hall sensor 1: Short circuit to positive.
1789/P0730 - Fault present in control module transmission... from web: "incorrect gear ratio in your automatic transmission."
1825/P2757 - Fault present in control module transmission... from web: "2757 code will be reported when the vehicle's onboard powertrain control module (PCM) detects an issue in the torque converter clutch pressure control solenoid circuit."
TCM:
0894 - The gear is implausible or the transmission is slipping
0741 - Actuation of torque converter lockup clutch is not possible
ESP:
5314 - The CAN message from control module Motor electronics is invalid or implausible. ( Accelerator pedal position )
