SL/R230: AUXILIARY BATTERY NOT LASTING
Old Dec 13, 2024 | 02:01 PM
elMacko's Avatar
SL 500 2004, Ford F-150-2014
Ladies, gentlemen R230 owners..I have been using the DURACELL AGM battery as auxiliary battery since I own my SL500 and have changed the battery 3 times in 3 years since they only last less than a year. I wonder if any of you have had the same experience and if not what would be the long lasting choice!
Thank you and keep on rolling in style!
Old Dec 13, 2024 | 03:59 PM
TripleDown's Avatar
2014 S63 2010 ML350 Bluetec 2009 SL550
How often are you driving the car ? These don't like to sit and discharge and that will definitely shorten the battery life.
Get a Battery Tender or something similar to keep a trickle charge on it and it should last 6-8 years easy.
Old Dec 13, 2024 | 06:00 PM
Rad Pro's Avatar
Mercedes Benz SL500 R230
Auxiliary Battery Not Lasting-Possible Solution
I own a 2004 MB SL500 for 3 + years and have installed a Duracell AMG battery when I purchased the car.
I still have the same battery and has been reliable with 12.3 volts at rest .
The only thing I added to negative terminal of battery is a quick connect/ disconnect switch . I use a trickle charger just prior to starting the car and believe that’s the reason the battery hasn’t failed.
The downside is that to connect the switch I have to unlock the trunk using the key and after the car starts have to syncronize the windows and the steering angle.
Same starter battery also still works great.
The only other thing I do when I park the car in the garage is shut the car down and disconnect battery.
I leave the battery connected when I park the car for hours and lock and put the car to sleep mode by pressing the key fob twice.
Just a suggestion.
Old Dec 14, 2024 | 06:23 AM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
I would strongly advise using a genuine Mercedes Battery, I have used Duracell and other off brands and they do not compare to the genuine product, if you cant leave your car for 3 ro 4 weeks without low voltage issues, you have a drain.
Old Dec 14, 2024 | 08:13 AM
SocksSL500's Avatar
2009 SL 550; 2022 GLE 450
I have a Genuine Mercedes aux battery installed March 2022 in my daily driver 2009 SL550 - no issues (so far!). Cheers Socks
Old Dec 14, 2024 | 03:21 PM
cdk4219's Avatar
95 SL600
The drain is probably what took the BCM out or contributed to its demise and possibly other things.
