SL/R230: Draining the ABC system.
Thank you.
If so just loop the outlet back into the inlet. This way it will stay lubricated but not build pressure.
If you drain it it will eventually seize up, so don't do that!
Another alternative is to fit a regular PS pump from any M113 engine without ABC such as an ML500 from that era.
