SL/R230: I am stuck on final trunk closure during retractable closure.
Is there some micro-switch that is not closing (maybe from the small tonneau flap) that is not engaging and allowing the process to complete?
These photos show the stall point where the flaps won't retract and the trunk deck lid won't lower and the cable for the small tonneau that I replaced.
Thanks for any input.
My friend who 3-D printed these said using a marine grade two stage epoxy might give these thing some added strength. Comments?
Is there another piece you fellows can recommend to substitute the original? Thanks!
BTW Mike, mine is Aegean also. I just had all kinds of body work done. Including replacing the whole front bumper. So I don't think I can re-afix the the Swiss license plate. Which I love.
BTW, you are in NC. Where abouts? My mom's family is from Davidson, Cornelius, Huntersville, Statesville, Denver, Hickory and Charlotte, etc. The Cashion, McCall and Brotherton families. Mom was born in Cornelius. Her parents the same in Cornelius and Davidson. Around 1900.
Thanks to all and especially Agean and Mike.
A question that came to mind, should you fill the top hydraulic pump when the roof is up or down? BTW, this is the first time since Jan 24 that the top has consistently worked. Hallelujah.
Just bumping this to see if anyone has any comments on if you should fill the reservoir for the roof pump when the roof is closed or open.
Now I have another question. When I replaced the cable I had the car in the manual raise roof mode. It allowed me good access to the cable mounting parts. But now that everything has been reinstalled with the addition of some rebuilt hydraulic cylinders the system will only work with the electronic control switch. Do you have an idea as to
what would be the best way to get at and replace this gas hydraulic lift?
Part number 40 in this diagram is Mercedes parts number 230–790–00–79
I just replaced my leaking top lock cylinder yesterday only to have the left trunk lock cylinder fail today. I knew this was a potential outcome and would lead to replacing all of the cylinders so that is the route I am going to have to take unfortunately.
Any advice for some of the trickier hose routing scenarios? I found doing the Top cylinder it was beneficial to first remove the left cover just inside the quarter window area. Went from damn near impossible to somewhat simple.
And congratulations on having a working top again.
The “cable” only needed replacing because I kept manually opening and closing the roof. That package shelf flap would get hung up and the tension caused that cable to fail. Also, when you manually open and close the roof you often times break the two little pegs that help align the forward aspect of the edge into the a pillar. When the car does this on its own it does a better job of alignment. You cannot just buy those replacement pegs. I had someone 3-D print them for me but they just didn’t hold up. Believe it or not, I replaced them with some thread enhanced black tubing that has some flexibility. This seems to give a little hoses a bit of flexibility while those pegs go into the a pillar. That seems to make a lot of difference to me. If you look back in this thread you can see the pictures of those flexible thread enforced hoses. By the way, in my opinion, those black pegs don’t do much for the alignment process. The alignment process is mainly accomplished with the hooks that lock the roof into the a pillar. But that peg on the right is needed to close the micro switch.
I am including the pictures of that flexible hose and how I have it fitted. It has been suggested that maybe I could get those printed in a more nylon based polymer. But I kind of like the way these work.
The “cable” only needed replacing because I kept manually opening and closing the roof. That package shelf flap would get hung up and the tension caused that cable to fail. Also, when you manually open and close the roof you often times break the two little pegs that help align the forward aspect of the edge into the a pillar for Home window tinting. When the car does this on its own it does a better job of alignment. You cannot just buy those replacement pegs. I had someone 3-D print them for me but they just didn’t hold up. Believe it or not, I replaced them with some thread enhanced black tubing that has some flexibility. This seems to give a little hoses a bit of flexibility while those pegs go into the a pillar. That seems to make a lot of difference to me. If you look back in this thread you can see the pictures of those flexible thread enforced hoses. By the way, in my opinion, those black pegs don’t do much for the alignment process. The alignment process is mainly accomplished with the hooks that lock the roof into the a pillar. But that peg on the right is needed to close the micro switch.
