SL/R230: Keyless Go problem
Old Sep 9, 2025 | 09:45 AM
Steve1116's Avatar
2007 SL550
Keyless Go problem
Purchased a 2007 SL550 back in May and quickly fixed a couple of minor annoyances. A bigger annoyance, however, is the non-functional Keyless Go, which has me stymied. The key works well for locking and unlocking and starts the car when inserted, but the start button on the shift lever does nothing. Is there a common trouble-shooting routine for such a problem?
Any suggestion or advice will be welcomed.
Thanks.
Old Sep 9, 2025 | 02:24 PM
MacVidMB-V8's Avatar
W209, W124
There is a fuse somewhere, start there.
Do you know for a fact that the key you have used to work with KLG?
It is possible that the key itself isn’t really KLG.
If you pull the PCB out of the key, from pix we can tell you. NKLG keys have just one copper wound inductor. KLG keys have 2 or 3 and much more crowded circuitboard. Early KLG required use of a card with the key. By 2007 should be just a key. (Oval panic button)
If panic button is a triangle, those don’t come apart if OEM.
If you only have 1 key, might be time to find a clever locksmith who can make a KLG 2nd key.
Old Sep 9, 2025 | 03:16 PM
Steve1116's Avatar
2007 SL550
Thanks for your response. The key seems to be the most important part of this process, so I'll start there and see where that takes me.
Old Sep 9, 2025 | 05:19 PM
g0rsq's Avatar
SL500
My 2005 keyless go keys only have one battery. Non Keyless go keys typically have two batteries inside.
Old Sep 9, 2025 | 06:18 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
It may be a new key that was programmed to the vehicle. The keys come programmed when ordered for DAS and EIS, but not KeylessGo, that part needs to be done by the dealer. I had the same issue after buying a car with a new spare remote the dealer ordered, but did not program.
Old Sep 9, 2025 | 06:33 PM
W209, W124
If you have a chrome key with triangular panic button it was made 2008 or later. In 2005 they were black plastic keys.
The MB keys with triangle panic button have 1 battery. The MB keys with oval panic button have 2 batteries. If 3rd party, all bets are off.
Old Sep 12, 2025 | 11:57 AM
Steve1116's Avatar
2007 SL550
Key is confirmed, now checking fuses. Is there a document that identifies the number and location of Keyless Go related fuses?
S
Old Sep 12, 2025 | 02:34 PM
W209, W124
Originally Posted by Steve1116
Key is confirmed.
S
What does this mean? You pulled the PCB out and verified multiple copper coils?
Old Sep 12, 2025 | 02:44 PM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
You are just flying blind without diagnostics. It could need key tracks reprogrammed, have a bad KG module, or a number of other things. Very rare to see a used R230 with 2 keyless go keys. Why do you think that they are keyless go keys?
Old Sep 12, 2025 | 03:09 PM
Steve1116's Avatar
2007 SL550
Counted multiple coil windings then took it to the dealer's parts department for confirmation. Only one of the two keys that I have is original - no surprise there.
Old Sep 12, 2025 | 03:14 PM
Steve1116's Avatar
2007 SL550
I recognize that the cause of the problem could be any number of things, including the after-market remote start/gate opener system installed. Trying to eliminate one problem at a time.
Old Sep 12, 2025 | 03:40 PM
W209, W124
Ok, those are the sort of details that should have been in first post.
1. You have 2 keys, neither working with KLG. Apparently they look different?
2. Someone added a “remote start and gate opener” feature. Do you know brand? There are about a million ways that could cause issues.
Old Sep 14, 2025 | 06:55 PM
g0rsq's Avatar
SL500
In the UK we do not have a PANIC button on the key fob
Old Sep 17, 2025 | 06:11 AM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
Xentry/das would point to your problem. As mentioned it can be key programming. It could also be the keyless go antennas or a module itself. I’m assuming no keyless doorhandles work either? Das with developer would get you through the repair in my opinion. When I went through something similar on an E 55 it was determined that the keys were not keyless go keys so I had to get a new key and after that I was able to do all of the repair diagnostics. In my case, all modules were working.
