SL/R230: Trunk locked 2003 sl500
I have ABSOLUTELY NO POWER coming in to the car my starter battery is brand new but the consumer battery is about three years old does anyone know how to open the trunk on this car. ?or can a locksmith perhaps open the trunk thereby access to the consumer battery ?Is there a way to replicate a key for it or what do you guys think
this is one unlucky situation I appreciate your help.
the output though ? You’re taking about is it a bolt ?
Basically find the alternator connect a positive to it ? Then you’d hit it with a screw driver or a pry bar ?
The suggestion is to connect a battery jump pack to the alternator large + wire and a chassis ground. Everything should then work - you should be able to start the car, open the trunk etc.
Actually have you simply tried starting the car? When the starter battery is good and the BCM and related parts are working correctly, the starter battery can power the entire car to perform an "emergency" start of the car.
