SL/R231: Do our cars have AVC?
Old Nov 26, 2017 | 05:44 PM
gkgeiger's Avatar
'10 C300, '15 ML250BT, '22 M850i Vert
If they do I can't figure out how to adjust it. Every time I pull up to a traffic light my wife is turning the radio down because she is embarrassed at how loud I have the volume set. I feel any convertible should have it. If we don't have it that's another thing they cheap'd on.
Old Nov 27, 2017 | 11:46 AM
Utopia Texas's Avatar
2019 SL550/2023 EQS 580 SUV
If it is there I cannot find it in my settings.
Kind of sad that such a expensive, high end auto, has some pretty mediocre accessories that work better in much less expensive cars.
Old Nov 27, 2017 | 11:52 AM
gkgeiger's Avatar
Thanks for the reply. 64 reads and only 1 reply. Yes, my C7 Vette had it and I know a lot of other less expensive cars do also. I thought maybe it was just me, that I couldn't figure out how to set or adjust it.
Old Nov 27, 2017 | 10:18 PM
Wolfman's Avatar
Super Moderator
SL's had automatic volume adjustments as long as I can remember. I don't believe there is a setting anymore in the MY17 and up (should be automatically enabled). One the MY13-16, please try to go to the car settings (press the vehicle button or select on screen), then go to the bottom area - system settings - there should be automatic volume control. At least this is where it used to be...
Old Nov 28, 2017 | 09:35 AM
gkgeiger's Avatar
My car is a '16 and I can't find anything anywhere that says Automatic Volume Control or anything like that. If it's automatically enabled "it's not working".
Old Dec 2, 2017 | 04:08 AM
Wolfman's Avatar
Super Moderator
I looked on ours and its not there. It was on older systems. Will check the manual over the weekend. I believe the menu has gone away with the introduction of the surround sound system.
That said, I know the setting was on our 2015 S550 but that Automatic Volume adjustment was a different feature altogether. That was for matching sound volumes between songs, similar to the sound check feature of iPhones...
You are referring to speed depended volume adjustment.
Old Dec 2, 2017 | 07:15 AM
gkgeiger's Avatar
Yes, a system which adjusts the volume level to match surrounding external noise caused by speed.
