SL/R231: Location of audio amp in 2017+ SL?
Received 3,418 Likes
2020 S560 Sedan, 2019 SL450, 2019 E450 Luxury Trim Wagon, '24 BMW I7 on order...
I believe this has been mentioned somewhere here before, but I can’t find it. Does anyone here with a 2017 or later R231, with the Harman-Kardon sound system, know the location of the amplifier? I believe the pre-2017 models had it in the trunk and the later cars with the B&O have theirs in the trunk, but I don’t see it in the trunk of my 2019 SL450. Is it behind the passenger seat where the CD changer used to be? Anyone? Thanks.
2013 SL550 (Lux Sport), 2006 CL55 AMG (Muscle). S550 (Wife's Sedan)
Stream....Regarding where the amp may be in the new models....
Since the newer, (2017+) 231's have (3) fewer speakers than the original (2013) 231 HK System did, it's possible that MB used what was formerly that speaker space for a new (and perhaps more compact) amp, as opposed to using the space formerly occupied by the 6-CD changer as you suggested...
Hopefully Wolf or someone else can answer your question definitively as to the amp's precise location!
Stream....
The newer, (2017+) 231's also have (3) fewer speakers than the original (2013) 231 HK System did, so it's possible that MB used what was former speaker space for a new (more compact) amp rather than using the space where the 6-CD changer used to be on the (2013) 231.
1986 560SL, 2017 E300, 2018 Sl550, 2020 E350
See the following thread and see my pics and details of my install (world of difference, so much so I'm buying the car @ lease end but, B4 the install I was thinking of not keeping it!)
The factory amp is under the smugglers box behind the driver (new amp installed in same place)
I stronly suggest you have similar install with the F & R pots to allow individual contol rather than a set and forget approach and I love showing what a difference the new AMP makes by using the switch in center of the 2 pots that allows default to factory......REALLY SHOWS THE DIFFERENCE...My dealers head mechanic and GM ect could not believe the difference
Any questions give me a shout.
SL550 back speakers PROBLEM SOLVED!
( 1 2 3 4 5 ... Last Page) My posts 4/4, 4/6 and 4/8 should give you full detailsAny questions give me a shout.
Streamliner (07-01-2019)
My car has a box with an opening top behind the driver’s seat. Behind the PASSENGER seat, there is a box with a cover that does not open. And your amp is behind the DRIVER’S seat?
Super Moderator
Received 3,171 Likes
The DVD changer was or is (for you) in the head unit. The amp should be on the driver side (below the box as mentioned) if memory serves. The passenger side holds the fuse box (visible by removing the cover plate facing the back of the seat).
Super Moderator
Good luck!
As if the 231's (2013) '6-whatever changer' doesn't also play (Audio) CD's....
FWIW, I actually did prefer the 230's 6-CD 'removable magazine system' to the CD/DVD changer system in my (2013) 231, but at least my 231 has one!...
Having said that, I must also say this!....Come on Man!...That may just be the new world' record for 'nitpicking'....
Super Moderator
That said I wish there would be more "fun" topics to discuss in this forum than "spare tires" and "audio amp locations".
[QUOTE=Wolfman;7793154 I wish there would be more "fun" topics to discuss in this forum than "spare tires" and "audio amp locations".[/QUOTE]
There would be, but one of the fun guys recently sold his SL!
Super Moderator
