SL/R231: Trick to replacing trunk struts?
Old Dec 7, 2019 | 12:27 PM
Oboingo's Avatar
2014 SL550
Is there a trick to replacing the trunk struts? I have OEM parts, matching what came with the car, but I can't lift the trunk lid high enough to get the new strut to go over the nub. Comes within millimeters, but I feel like I'm putting to much pressure pushing trunk lid up to get it to line up. Old part comes on and off no issue. Anyone changed their trunk struts and have a suggestion?
Old Dec 7, 2019 | 12:42 PM
Keon's Avatar
SL550
Have you tried compressing the struts a bit?
Old Dec 7, 2019 | 12:53 PM
Oboingo's Avatar
2014 SL550
I tried. I put one end on a cloth on the ground and pushed down pretty firmly. Is there a trick to compressing it?
Old Dec 7, 2019 | 01:01 PM
Oboingo's Avatar
2014 SL550
I just tried again and I can't compress it. I googled and found a post about another vehicle where someone used ratchet straps, but that sounds too bulky for where these struts need to be placed.
Old Dec 7, 2019 | 01:11 PM
Keon's Avatar
SL550
Ratchet straps do sound a bit bulky, but then again if it worked for them, shouldn't it work for you?
Old Dec 7, 2019 | 01:52 PM
Utopia Texas's Avatar
2019 SL550/2023 EQS 580 SUV
Though they appear to be the correct strut take one of the extended worn ones and place on the ground with a new one and see if they are the same length.
Old Dec 7, 2019 | 02:48 PM
Oboingo's Avatar
2014 SL550
They were same part number. This is the solution:
Amazon Amazon
Irwin Quick-Grip 18" clamp
It was still a bit fiddly. Snap on the top first, then use the clamp to compress the strut and snap on the bottom. It will want to snap out of the clamp, but after a few tries one will figure out how to do it. I guess I'll have the tool 5 years from now when this set of OEM struts go out.
Now my trunk stays up!
Old Dec 9, 2019 | 06:51 AM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
https://www.amazon.com/IRWINQUICK-GR...s%2C149&sr=1-2
I have a couple of those; didn't pay anywhere near that price tho'.
https://www.acehardware.com/departme...clamps/2406429
Old Nov 1, 2020 | 02:49 PM
NiceMerc's Avatar
C300 and SL500
I found the quick grip clamp awkward, but this small band clamp worked very easily for me.
The fabric is only 1" wide and it quickly comes apart so get the band off the strut once it's in place.
No more bumps on the head in cold weather :-)
Gary
Old May 3, 2022 | 07:41 PM
elliotpat's Avatar
Mersedes
between 100 and 170 pounds
Old May 5, 2022 | 08:20 PM
David2244's Avatar
2013 SL350
With an assistant supporting the boot lid remove one strut and fit the lower end of the new strut first. Then with the help of the assistant applying some upward pressure (not brute force) on the boot lid the top end can now be fitted
