SL/R231: Frame rail / bumper protection
Old May 25, 2020 | 10:30 AM
PAPA PA's Avatar
AMG SL63
As I look to lower the SL on Braun’s spring this month, I am wondering if MB or any aftermarket company makes frame rail protectors akin to what I have on my Corvette?
I’ve done a fair bit of searching, but know this group is generally ahead of the curve - so I thought I would check in.
Rails (and the little frame forward wheels on the radiator support) were invaluable for the unexpected speed bump or unavoidable steep pitch curb. Well worth the extra weight.
If anyone is aware of something similar - please share. Otherwise it will be off to the metalworker and see what we can fabricate.
Thanks in advance!
Old May 26, 2020 | 04:45 AM
toi's Avatar
toi
2014 sl550
i had them on my c6, after my mechanic made a hole on the rocker panel (with lift arms) which are bonded to cabin frame.
However in the SL those panels are replaceable i believe.
SL underside might not have the same type of space to put one in like the corvettes
It might help with very low bump situation i suppose.
good luck with your search.
Old May 26, 2020 | 02:42 PM
Wolfman's Avatar
Super Moderator
The only thing that will see damage on a lowered SL (springs) will be the front bumper... with normal driving that is. Taking on a speed bump at 40 mph or so could so damage to the undercarriage but likely only dent a panel and destroy some undercoating. The rocker panels and simply removable side skirts and wouldn't see a hit
Old May 26, 2020 | 10:24 PM
PAPA PA's Avatar
AMG SL63
Thanks for updates folks. I may look to see if there are some nose protectors to mount. I’m generally very careful about approach angles and what not with a low car - but there is always that one time. . .
Old May 27, 2020 | 12:10 AM
toi's Avatar
toi
2014 sl550
Post some pics of before n after of springs and how the ride quality is pls
Old Jun 27, 2020 | 07:42 PM
PAPA PA's Avatar
AMG SL63
https://mbworld.org/forums/sl-class-...-lowering.html
