SL/R231: Changing SL Rear brake pads with the electronic park brake....
Old Jun 15, 2020 | 02:04 PM
Rdarsa's Avatar
Sl500 r231
I have a mechanic who is scared to change the rear brake pads on my 2013 R231 SL500 (pre face lift) due to the fact that there is an electronic hand brake.
Is there a menu somewhere that you can access that is designed to release it while the car is parked up - or do you just follow the instructions to set the car up to tow in the manual.
Is it simple or are other tricks needed to get this job done.
Thanks in advance for any suggestions.
R.
Old Jun 16, 2020 | 10:31 PM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
Yes you need to retract the pads, can be done through the service menu.
Old Jun 19, 2020 | 05:17 PM
Piperkid's Avatar
2015 SL400, BMW Z3, Datsun 280Z, a couple of jeep Grand Cherokee's - And a Commander Airplane
Time for a new mechanic
R.
Many cars use an electronic Parking Brake these day's - Generally easy to turn off through software.
Cant imagine a mechanic who has not done so yet,
Old Jun 19, 2020 | 09:57 PM
Keon's Avatar
SL550
If your mechanic can't figure out how to back out an electronic parking brake, you need to find a new mechanic.
Old Jun 19, 2020 | 10:19 PM
rmorin49's Avatar
Veteran: Army
2015 SL400; 2019 X5M40i
A friend and I had no problem installing rear brake pads on my 2015 SL. I released the parking brake before the install and the old pads were easily removed. No software changes were needed.
Old Jun 20, 2020 | 03:51 AM
Rdarsa's Avatar
Sl500 r231
Thanks for the help.
