SL/R231: Please Post Pics of your Phone Mount Set Up THX
Old Sep 6, 2021 | 11:34 PM
thunderbenz's Avatar
2015 SL400 R231
Hi,
I use Proclip/Brodit for all my cars as it is OEM looking and fit and quality is great. But, for some odd reason they discontinued their mount for the R231 and all other SL cars. They still sell one for the 997 Porsches so not sure why I chose to discontinue it for the SLs. Now, I'm stuck with what to buy as my phone mount. I want to see the phone when I'm driving and would want something to look OEM.
Thanks in advance.
Old Sep 7, 2021 | 06:32 AM
ZCARGUY's Avatar
2019 SL450
Scosche suction cup magnetic phone mount.
Apparently this is a redesigned newer version:
https://www.scosche.com/magicmounttm-pro-window-dash
Old Sep 7, 2021 | 01:21 PM
Bitbytr's Avatar
'13 SL550 Mars Red, Designo White interior, B and O sound
It is obviously problematic in a number of ways: it necessitates sticking a plate to the phone or its case; and that, in turn MUST be in a position that doesn't interfere with the wireless charging function. Meh... Not good enough for me I'm afraid. Thanks!
Old Dec 29, 2024 | 11:20 PM
sjmohr's Avatar
2014 SL 550 Sport Package
I really wanted something that would attach with suction as I was hesitant to use 3M tape on the interior. I found a mount that mer all my needs except the magnet was extremely weak and the phone slid around and occasionally fell off. None of the mounts with a MagSafe and suction cup attachment were small enough to mount where I wanted so I hacked together my own solution.
I bought this mount:
Amazon Amazon
The base allows full maneuverability and is small enough to attach on the trim. However, the magnet holding the phone was weak. So, I removed the rubber insert where the phone attaches, bought a cheap MagSafe charger with a strong magnet (I was only interested in the magnet, not actually charging) and used epoxy to attach the magnet to the base.
It’s the perfect solution for me. Someone should manufacture it.
Old Dec 31, 2024 | 09:19 AM
jmattioni's Avatar
2014 SL65 AMG, 2018 S560
This mount uses double-sided tape to mount to the dash and is magnetic on phone side. The phone needs to have a flat metal ring stuck to the back of it. I was doubtful that the tape would hold, but it's good so far.
Old Dec 31, 2024 | 10:22 PM
DBDSL63's Avatar
2013 SL63
After seeing the Lisen setup in another thread, I put this in my daily drivers. I plan to place this in my SL63 in the spring. https://a.co/d/3zppRba
Lisen Magnetic Phone Mount
Old Jan 3, 2025 | 11:55 AM
slk55er's Avatar
2024 GLB35 AMG, 2020 S560 Coupe
I have this on all of my vehicles and have used these for the past decade for my Android phones. If you have a small flat area to attach the adhesive pad and phone holder you'll be all set. Just place one of the thin steel plates on the back of all of your phones. It is so convenient to just place a phone on the mount and easily remove it. An easy $7/car solution that is smaller than the ones with the larger halo ring.
Amazon Amazon
Old Mar 28, 2025 | 07:26 PM
Jammer005's Avatar
Mounting Base Ring?
Thank you for the images. I just received my Lisen and plan to mount in the same spot however I've noticed that the kit comes with a Mounting Base - a slightly larger ring that is meant to be stuck down first and then the holder is stuck to that base. I'd prefer not to use the mounting base as it takes up a lot more room and doesn't look as nice.
Has yours held up without any problems since there seems to be a slight curve to the mounting area.
Old Mar 28, 2025 | 08:02 PM
jmattioni's Avatar
Yes it's holding. I didn't use the base ring.
Make sure to follow the instructions to wait 24hours before using the mount. Also, the magnet is very strong. When I remove the phone from the mount I slide it off to minimize stress on the mount.
Old Apr 18, 2025 | 12:11 AM
G. Rosales's Avatar
2013 SL550, Past: 2015 C250, 2007 R350, 1972 280SE, 2006 R500, 2003 E320, 1998 C230K
Custom phone mount
I purchased this safe-mag phone holder from Amazon
[url=http://Syncwire Fits MagSafe Car Mount... [ame]https://www.amazon.com/dp/B0CTGXQJJX?ref=ppx_pop_mob_ap_share]Syncwire car mount[/ame]
I liked the reviews and the price.
But I didn't want to glue it to any surface on the dashboard. I didn't want to damage it, so I thought of an alternative solution.
I noticed the dash clock was in a perfect position for the holder, and designed and 3D printed a cover that would serve as holding surface for the mount.
A simple cylindrical design that fits tightly, without damaging, the clock, slides into place and snugly stays in place, while providing the perfect surface for the mount.
Will come off without effort and no damage to the dasbhoard.
see pics for details.
Old Apr 21, 2025 | 09:44 AM
thieany's Avatar
r231
Looks perfect. Even if plastic, wouldn't mind strong adhesive on something like this. Happy to buy one if you want to make more.
Old Apr 21, 2025 | 01:03 PM
G. Rosales's Avatar
That was my main goal. No adhesive on my dashboard.
This little device will fit perfectly over the clock and provide the flat surface required for the holder.
Old Apr 21, 2025 | 01:07 PM
G. Rosales's Avatar
Thieany, please send me direct message if you would like to get one for your car.
Old Apr 21, 2025 | 05:55 PM
thieany's Avatar
r231
I sent friend request. Apparently necessary to message directly.
Old Apr 24, 2025 | 07:32 AM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
I couldn't live without the analog clock, but I'm sure many will find my setup lacking. Pro-clip is actually for a GLE (I have another in my ML400) and the magnetic mount/charger is wired simply to the 12v in the passenger footwell. I've considered using a longer cord that I could route all the way around the back of the console, tucked into the floor mats but this works just fine. If I had CarPlay I'd be content to leave the phone in my pocket.
Old May 3, 2025 | 04:00 PM
thieany's Avatar
r231
Thank you Mr. Rosales
Mr. Rosales made one for me. Works great with phone & split screen iPad. iPad cellular includes GPS chip.
Old May 6, 2025 | 12:17 AM
G. Rosales's Avatar
I am glad you liked it!
That iPad setting looks amazing.
cheers
Old May 7, 2025 | 05:44 PM
eddieo45's Avatar
Originally Posted by petepantelidis
what year GLE is the mount that you purchased to put in your R231?
Pete
I bought THIS ONE from Rennline; after I determined that it fit in my SL as well as my ML I bought a second bracket for $25 and attached a magnetic mount I already had (I've bought nearly a dozen different charger/mounts)
Old May 13, 2025 | 12:59 PM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
Low Tech but Low Impact
That bottom expands into the cup holder via screw in, or loosen screw adjuster to contract- See last picture
I just stow it in the center console when I'm not using it....
Good Luck
Old May 28, 2025 | 01:11 PM
HighPercentile's Avatar
2017 Mercedes Benz SL550 w/ ABC; 2010 Cadillac SRX 2.8L Turbo
I too used a Lissen model (they have quite a few) and absolutely love it. The magnetic ring holds my iPhone 15 Pro TIGHTLY, it’s not coming off even if the car went *** over keister. It has an almost infinite range of motion and is very well designed. I also did not use the backing plate and have had no issues after over a year or 2 in my hot Florida climate. In fact, I love the placement, as to my eye it makes the dash more symmetrical with the opposing Engine Start/Stop button in the other corner. ;-)
Old May 28, 2025 | 01:21 PM
Jammer005's Avatar
Yes, I'm still working on my technique to remove the phone as that magnet is very strong. Good point on the symmetry!
Old May 28, 2025 | 02:33 PM
lol, thanks! Yes, when I was deciding where I was going to place it, I noticed that one area is bare and almost screams for an attachment. The moment I held it there I knew that was the right spot for it.
Old Jun 2, 2025 | 07:29 PM
thieany's Avatar
r231
Fun Playing with this
The Acmezing just wedges easily against base on windshield and instrument cowl.
Old Jun 3, 2025 | 11:37 AM
G. Rosales's Avatar
Nice setup!
