SL/R231: Low Voltage can’t figure out
Old Nov 10, 2021 | 02:12 AM
eblount's Avatar
SL 550
Hello,
I have a P0562 code. I have replaced the alternator, the AUX battery and the starter battery is good. I can’t figure out why the low voltage persist. Right headlight occasionally flickers at stoplights after short in town driving. Any help would be appreciated. Thanks!
Old Nov 10, 2021 | 04:38 PM
David2244's Avatar
2013 SL350
You say the starter battery is good, has it been tested and proved to be OK.
Old Nov 10, 2021 | 06:10 PM
eblount's Avatar
SL 550
Starter battery has been tested and the AUX battery is new.
Old Nov 10, 2021 | 07:03 PM
David2244's Avatar
2013 SL350
Is your scan tool capable of resetting fault codes and did you try clearing it after fitting the new components.
Old Nov 11, 2021 | 02:30 AM
eblount's Avatar
SL 550
Yeah, everything has been reset.
Old Nov 11, 2021 | 08:25 AM
David2244's Avatar
2013 SL350
PM sent
Old Nov 19, 2021 | 01:53 PM
David2244's Avatar
2013 SL350
Any nearer a resolution?
Old Nov 19, 2021 | 02:00 PM
eblount's Avatar
SL 550
nope. Still happening. It only happens when idling or going slow. The new alternator works well apparently. Both batteries are good
Old Nov 22, 2021 | 05:51 AM
iamahoo1's Avatar
2013 SL550
Are you in key FOB hell?
When you are home, srore all working key FOBs at lease 30 ft away from the car and behind a masonry wall if possible. When I brought my SL550 home from purchase at our local dealer, I hoticed that my CTek battery minder was showing low charge after sitting for a couple days without driving and this with a brand new Merc battery. As long as the zillion+1 system modules, ROM computers and special sensors reporting to the ECU can communicate with FOBs, they just sleep and continue to draw juice from the batteries. Also, get a CTek smart charger and keep it hooked up when not using your SL for a few days to make your tee time or hang at the yacht club. These cars love fully charged batteries and all systems seem to work better when you leave the garage after being attached to the CTek all night.
Old Nov 22, 2021 | 12:42 PM
eblount's Avatar
SL 550
Thanks. Not a bad idea. However, I don’t think it’s the key being too close. They are stored a considerable way away. The strange thing is that the voltage on the car now noticeably drops when idling. There is a brand new alternator so it’s not that. I floored it off of a stop light a couple days ago and it is been a lot worse since then.
Old Nov 22, 2021 | 01:59 PM
WN1X's Avatar
2013 SL550, 2017 GLE350, 2018 Audi Q3
Did they check/replace the voltage regulator?
Old Nov 22, 2021 | 02:00 PM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
How are you measuring the voltage drop? Is it the right headlight dimming? Or using your diagnostic scan tool? Does the car start or is it dead after a couple days sitting?
Old Nov 22, 2021 | 02:01 PM
eblount's Avatar
SL 550
Isn’t the voltage regulator built into the alternator in this model?
Old Nov 22, 2021 | 02:05 PM
👍 Absolutely
Old Nov 22, 2021 | 02:11 PM
It’s piggybacked onto the alternator.
Also look at the battery relay module.
"A0009822023"
Old Jan 23, 2022 | 11:49 AM
Bay Leaf's Avatar
SL 350 R231
An old thread this I know. What was the outcome. Was it an earth / grounding problem?
Old Jan 25, 2022 | 08:02 PM
eblount's Avatar
SL 550
There were like 5 electrical shorts. It was a total pain.
Old Jan 26, 2022 | 05:09 PM
David2244's Avatar
2013 SL350
Is it now resolved?
