SL/R231: Turning OFF Traction Control and ABS
Old May 31, 2022 | 06:13 PM
Ebeylier's Avatar
2013 SL 550
Guys, am going crazy here! Trying to turn-off ma R231 2013 SL 550 ABS and Traction control OFF to change my rotors and pads and paint my calipers, and a tech told me I HAD TO turn off ABS and traction control. So I went on the internet, and found many times the same procedure: 1/ go ignition position 1 on Odometer, press left to get on trip and 2/ go to position 2 and press the call button first, hold it and press OK to get the Vehicle Data / Dynamom menu, press OK, click OFF and your are done. Simple right...! Well, no matter how many times and how long I tried pressing this Call button + OK, I NEVER get to the Vehicle Data menu....! LOL! What am I missing here...!? Anybody, please help...!
Other idea, how do I physically disconnect the ABS box?
Cheers,
Eric
Old May 31, 2022 | 07:57 PM
Ebeylier's Avatar
2013 SL 550
OK guys..... I REALY feel stupid right now.... I had to close the door! LOL! Then got access to the Vehicle Data menu! No need to share any answer, nor make fun of me...! ;-) Cheers, Eric
Old May 31, 2022 | 08:41 PM
Utopia Texas's Avatar
2019 SL550/2023 EQS 580 SUV
Don’t feel bad. I think most of us could come up with similar stories….
Old May 31, 2022 | 08:55 PM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
If you have an R231 the only thing you will need to do is put the rear brakes in service position.
If you get new pads, you may also need to adjust the rear piston by screwing it in with a special tool.
DO NOT let the brake system run dry. Cap the brake lines right after you disconnect them, and THEN remove your brake calipers. If the brake fluid does run dry you might need to bleed the ABS pump via STAR/XENTRY. Disabling TC and ABS has no effect on the R231 bleed procedure and isn’t needed. (R230 with SBC is a different procedure )
Many folks just paint the calipers on the car….
Good Luck.
Old Jun 1, 2022 | 07:19 AM
JettaRed's Avatar
Veteran: Army
What?! Pass up an opportunity to make fun of you? No way.
Actually, R230s with SBC did require disabling the brake system, like @crconsulting said. I've replaced my pads on my R231 (with the "H.D. Brakes" code U28) without disabling anything. Make sure you have your parking brake off.
Old Jun 1, 2022 | 07:21 AM
JettaRed's Avatar
Veteran: Army
EDIT: Disregard the below and follow the video in the post from @crconsulting
You may also consider getting the proper brake piston tool when changing the rear pads. Something like this is very useful, especially if you have more than one brand of car you work on.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Old Jun 1, 2022 | 07:25 AM
JettaRed's Avatar
Veteran: Army
EDIT: While the above statement is true, putting the brakes in service position would be so much easier.
