SL/R231: Removing round AC vent
Old Jul 11, 2022 | 07:37 PM
jrupp's Avatar
2013 SL550
Anyone ever removed one of these? I can't find a YouTube video for the R231 but similar MB style vents pop out using some kind of pry tool. I'm trying to isolate a little rattle and I think it may be in one of the vents. Just trying to find out if any of out intrepid forum members have any guidance. Thanks.
Old Jul 17, 2022 | 12:38 AM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
Missed your post but, there are 4 clips holding it in.
Sometimes it helps to look at the part to understand how it’s held in place
Good Luck
Old Jul 17, 2022 | 10:12 AM
chassis's Avatar
2017 GLE350 4MATIC
Trim pullers. Used as a pair they balance the forces on the fragile plastic trim pieces.
Old Jul 17, 2022 | 10:35 AM
I could see those hooks working for that application. Smart!
I typically use thin flexible sheet styrene plastic (sometimes business cards can work too) and get them under the clips as I push the vent in.
I use one under each clip, in this case 4.
in case OP wants to try the hook method mentioned above:
Amazon Amazon
Good Luck
Old Jul 17, 2022 | 06:47 PM
jrupp's Avatar
2013 SL550
Once again, forum members to the rescue. Thanks, gentlemen, "pry pieces" ordered.
