SL/R231: What to use for "spare tire" if not using run flats
We got the runflats off the SL and it drives and rides like a different car. It is worth the tradeoff for us. Even if you have runflats and have a flat, you probably cannot fix it. You will need another tire. Good luck finding one wherever you are. Most places will not fix a runflat tire. With my Michelins, I plan to get to a tire shop and have the tire fixed and go from there.
The obvious next question: What tires are did you put on to replace the run flats?
I carry a small flat jack (if the nail, etc. is in the back and I can't get to it by simply turning the steering wheel) a tire repair kit, gloves, fix a flat, lug wrench, razor blades and an electric air pump. All of this fits under the rear hatch below the lower section. I have only had one leak so far, but at least I have a chance to do the repair should a flat happen. I have AAA which gives me 6 free tows per year, as well as my own insurance that also provides free tows. (Sometimes one service takes longer than the lower, so I go with which ever can get to me first)
Let me say this with all respect to any prior posters, or those that may post later. DO NOT use anyones stories about driving for x amount of years and never having a flat, an issue, a problem, a whatever as a gauge for you and your safety, or preparedness. The roads you travel, the city you live in, the distances you drive, how you drive, as well as the time of day you drive can vary greatly from anyone on this site. Although I have not had a flat in my SL yet, I have had a leak in one tire when I first got my AM wheels put on. (bad seal) I was able to make it back to the tire place (1 mile) before the tire went all the way flat. I have had about 6 flats in my SUV over the last 5 years for a number of reasons. I have changed the flats myself most of the time, but the last few I had AAA change the tire.
From one SL owner to another, either keep your run flats, or put together a setup to help out should that rare one in a million chance you do get a flat. It looks like you are doing just that, so great. One other thing, I drive my car far and a lot. I am not the guy that buys a nice car and then doesn't drive far from home for fear of getting a flat. Tow services are slow at times, get lost, or whatever. Tires shops and the dealers are not open 24 hours and nowadays you can have an issue if you think you can just show up for service without a long wait. Many are doing appointments, but not all. Plan for the worse and you will be covered.
Best wishes....
One example of our use is that we are taking the SL to Arkansas Ouachita mountains to watch the leaves turn. It is one of the top autumn leaf changing drives in all the USA. We will take the Expedition for all our stuff and the dog. We are taking the SL also for the mountain leaf drives and curvy highway excursions.
... We bought it to use it......it gets babied for sure - but it also gets driven.I think Michelin makes about the same tire now but gave it a different designator... The car is so much better without the runflats. The RIDE is so much better.
You posted this earlier on this thread...
I am very interested as being as prepared as I can be for this. What kind of flat jack did you buy for the SL? And why would you need it? And where would you lift the car? I would be scared to jack this car up i think. I read that it can screw up the top. And -- Why a lug wrench?
This conversation reminds that i wanted to add a spray bottle of soap bubbles... I plan to plug a leak.
If the nail is in a rear tire and I can't reach it easily by simply turning the steering wheel like on the front tires I will jack the car up to have better access to the problem area. Also if I don't feel like laying on the ground.
Under the rear hatch cover. My items fit without issue.
There are Jack points under the car, I have jacked up the car multiple times. To look around, to check for leaks and rust, to work on my calipers, etc. I have had zero issues jacking up the SL.
If I just don't feel comfortable on the ground, or am having trouble reaching something, or completing the repair, or if the weather is not great, whatever I will take the wheel off to get at the repair more easily. I am old and sometimes things hurt for no reason. Also the ground may be wet, or whatever.
Good idea,
I am adding some stuff for this trip that I don't normally worry about because we will be away from civilization a little. We rented a house for a week and will explore the forest areas. So I am adding a floor jack to the SL just in case. I am preparing for possible no cell service in some spans of our drive. In adding the floor jack. I read about an adapter gizmo that would help. I hope I never get into position that I need to jack up a wheel..... I am trying to find the proper lift points for the jack. .... and looking for info about if I need this adapter or not?,?? I hope this link to one if them works.
https://picclick.com/Mercedes-Benz-M...890552162.html
Will I need one of these if I get in a bind and I have to jack up a tire out in the boonies?
And here is the tool I would buy if I was going to buy one.
The reason I haven't bought this tool is that the round base of the tool (3" as stated in the description) is too big for the saddle of my floor jack. Accordingly, I just use the jack as is. Unless you are going to be jacking up your vehicle on a regular basis, I would say it's OK to go without a jack pad tool. The jack pad underneath the car seems pretty sturdy for infrequent or emergency use. No matter what you decide I would definitely recommend a dry run to test your solution, including making sure you can remove the lug bolts on all your wheels.
Sounds like you have a great trip planned. May the journey be inspiring, and the mechanicals be uneventful :-)
