SL/R231: Replacing rear red brake caliper cover
Old Oct 11, 2024 | 09:36 AM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
Originally Posted by crconsulting
Now also available are the actual plates themselves. (UK seller above?)
eBay Mercedes Caliper Plates
They look like a quality product, just make sure to compare pin spacing to get the correct one as there are different sizes. (not affiliated with seller)
Link didn't work. Is this seller you referring too:
Mercedes Brake Caliper Logo Plate 32354536 REAR W166 W176 W292 Billet for AMG | eBay
Old Oct 11, 2024 | 10:12 AM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
Originally Posted by E55 KEV
yeah, that’s the one
Old Nov 10, 2024 | 10:13 PM
Lambojunky66's Avatar
How can I order and price please?
Clips now available - I sell them![/QUOTE]
Old Mar 17, 2025 | 07:20 PM
c230K415's Avatar
AMG GTS
Stumbled on this thread while figuring out why my caliper cover came off randomly. Realize the underlying issue may be the clips that are actually one-time use but doesn't seem to be replaced by any technicians that work on the brakes. I recently had my calipers refinished and I am guessing the clips we reused which is why I lost a cover. Now that I have a cover and want to be absolutely sure BOTH covers are tightly secured, what is the best way to ensure the clips/cover are secure to the caliper? I notice even with fitting on new clips/covers there is still some looseness and play which makes me think it will come off again. I'm actually able to pry the covers off with my hands which seems like it should not be that easy to come off. Thoughts as to what one can place inside the holes or place onto the 2 prongs that secure the cover/clip to the caliper? Is there some adhesive promoter I can spray on? Or some other substance I can apply before installing?
Old Mar 17, 2025 | 07:30 PM
Clips are directional. Make sure they’re getting pushed in the right direction. They can be pulled off by hand normally, but should take some force to do so….
Though tough to bend, you can bend the teeth to give the clip more “bite”.
Good Luck
Old Mar 18, 2025 | 06:44 AM
c230K415's Avatar
AMG GTS
Thanks, @crconsulting . Curious - which direction should the clips go in? I currently see that that when I pulled the covers off, the clips have the angled-out prong side on the side of the cover (as opposed to being on the side going into the actual caliper). Photo attached
Good Luck
Old Mar 18, 2025 | 11:58 AM
  #32
It’s been a while, but that look right…
The goal is for the directional teeth have to bite both the outer diameter of the dowel and inner diameter of the caliper bore.
Another issue is the cover is made out of very soft aluminum. They’re kind of a “one time use” part. So pulling them in and out of the brake caliper can eat into the soft aluminum dowels on the cover. You may have to bend the tabs a little to get them to bite more, but try to avoid pulling them in and out if possible.
I’ve had the best luck by putting the clips either half way in the bore, or halfway on the dowels, and THEN pushing the cover on. That has a tendency to seat the cover with the clips midway, biting the maximum amount. The goal is to get the clips to sit halfway on the dowels and halfway in the bore. The clips will not really bite into the cast iron as much as they bike into the soft aluminum cover. The way they are right now, the right one appears to be sitting too high on the dowels.
In reality, there should be no force pushing on the cover when it’s on the car. I think the clips/dowells sometimes corrode causing them to fail. The other issue I’ve run into is techs using caliper spreading tools to compress the piston, but mistakenly using the cover to push against. Then once they realize they f***ed up, they just push it back in haphazardly. Of course it takes a while before the cover falls off and/or the owner realizes it….
Hope that makes sense.
Good Luck.
Old Mar 18, 2025 | 02:11 PM
  #33
c230K415's Avatar
AMG GTS
Thanks for all the helpful guidance. I did pull the clips off 2-3 times and noticed it was cutting deeper into the dowels. What a terrible design to make the dowels out of such soft aluminum. When the new clips arrive, I'll insert them in a way where the clips (that make contact with the dowel) aren't resting on the "old" grooves created from previous installing. When I do install, I'll try it with the clips seated much lower on the dowels so that they're hanging off a bit before I push into the caliper.
Old Jul 25, 2025 | 03:44 AM
  #34
BRGR TME's Avatar
2018 E63S Wagon
one of my caliper covers is loose. noticed last few times i washed the car, i kept hearing a clicking noise as i cleaned the wheels. thanks to this thread, I checked today and one of the covers is loose, doesnt seem it will fall of yet, but i definitely need these clips......
how do we buy the clips?
Old Jul 25, 2025 | 03:45 AM
  #35
BRGR TME's Avatar
2018 E63S Wagon
[/QUOTE]
Are clips still available?
