SL/R231: Left side mirror and front cup holder repair
Old Dec 12, 2022 | 11:22 AM
compaddict's Avatar
2016 S63, 2013 SL63
Our new to us 2013 SL63 pax side mirror does not adjust front to back. What is typically needed?
And the front cup holders internals are broken too.
Insight please!
TIA,
Vince
Old Dec 12, 2022 | 11:59 AM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
Insight please!
TIA,
Vince
Cup holder is an easy one, it's a fairly common problem. You can get them for about 50 bucks from Mercedes (or Amazon) PN: A231 8100 00 13
They mostly break when us 'Merican's try to stuff Big Gulps in our Euro sized cup holders
Mirror could be a few things. I wouldn't throw parts at it until you can find the exact cause of the malfunction. I'd see if any codes pop up in XENTRY.
If you don't have access to that, you could power the motor in the mirror seperately to see if it works. Motor will usually have wiring to move it up and down and left to right.
If the mirror motor functions properly, then I'd check door panel switch, connectors & wiring. There's also a door control module (relay) in there to check....
Good Luck.
Old Dec 12, 2022 | 12:56 PM
compaddict's Avatar
2016 S63, 2013 SL63
Sweet and thank you so much! The PN doesn't come up?
I will run Xentry and diagnose.
Vince
Old Dec 12, 2022 | 01:27 PM
woops added an extra 0 in there....
A2318100013
https://www.autohauspartsdelivered.c...BoCbL4QAvD_BwE
Old Dec 12, 2022 | 01:36 PM
compaddict's Avatar
2016 S63, 2013 SL63
Love links!!
Thank you again.
Old Dec 22, 2022 | 09:02 AM
spinalator's Avatar
2017 SL450 2022 GLC300
Thank you crconsulting for that parts link for the cup holder. Mine was broken and the replacement just arrived and installed. Simple and relatively inexpensive.
Old Dec 22, 2022 | 03:36 PM
compaddict's Avatar
2016 S63, 2013 SL63
Got the cup holder!
TY
