SL/R231: Rear Diff Fluid Change
Old Jun 21, 2025 | 01:39 PM
JettaRed's Avatar
Veteran: Army
I have 56,728 miles on my 2015 SL400 and decided to change out the rear differential oil. There’s no scheduled maintenance for doing that unless you have a limited slip differential. Mine is non-limited slip. To my surprise, the stuff that drained out looked like coffee (without cream and sugar). The stuff I put in was Castrol Syntrax 75W-90 and looked like golden honey.
Has anyone else change their rear differential oil and was it black?
Old Jun 21, 2025 | 03:48 PM
JettaRed's Avatar
Veteran: Army
Old Jun 22, 2025 | 08:33 AM
BMBLBEE's Avatar
2014 SL63 AMG / 2024 Porsche Macan GTS (Winter beater)
Changing all fluids on a regular basis is good. Over the years I have changed the diff fluid on my Corvettes every 4 or 5 years and it always looks very dark. The Vettes did have limited slip.
Old Jun 22, 2025 | 10:04 AM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
Always hard to tell from internet pics. How’s it look lit from the back?
Fluid looks “ok” not new. I’ve seen better, I’ve seen worse. No metal shavings picked up by strong magnet right?
You could get it tested if in doubt….
Driving a car hard will obviously create a little more wear and 2nd hand cars can be a mystery. You never really know if someone replaced it, used an additive or wrong oil.
For what it’s worth, when I swapped my stock diff for the 471-LSD and drained the oil at 45k, it looked pretty close to that, maybe a little cleaner. As mentioned, internet pics are always hard to compare, colors on LCD screens look different from screen to screen.
Good Luck
Old Jun 22, 2025 | 10:10 AM
JettaRed's Avatar
Veteran: Army
Thanks. For an accurate description, go to your locak Starbucks and get a cup of their dark roast.
Old Jun 22, 2025 | 10:14 AM
still have a greenish hue under lighting? (while pouring)
No noise?
No metal?
Old Jun 22, 2025 | 11:17 AM
JettaRed's Avatar
Veteran: Army
A slight shimmering. But nothing visible to the naked eye.
Old Jun 22, 2025 | 02:05 PM
As long as you’re not getting metal you should be good. I know MB has used an assembly lube on non LSD diffs in the past. Some bearings will also come pre-packed for assembly, or to hold them in place. A little too much of that assembly lube may darken fluid. (especially if it’s Moly based)
I’ve used this stuff in the past on roller bearing assemblies. Great product….
Amazon Amazon
You could stick a borescope in there to see condition of ring & pinion if you’re concerned.
Good luck.
Old Jun 22, 2025 | 08:33 PM
JettaRed's Avatar
Veteran: Army
https://www.amazon.com/Lubegard-1925.../dp/B000B8YDUO
Ha! Me too. And I'm not concerned. There are no symptoms.
Old Jun 23, 2025 | 07:36 PM
rmorin49's Avatar
Veteran: Army
2015 SL400; 2019 X5M40i
JettaRed, How much fluid is required for our cars? Also, are the diffs limited slip? I'm waiting on FCP Euro to tell me what fluid they recommend? Seems MB has changed the recommended weights, is this correct?
Old Jun 24, 2025 | 12:00 PM
JettaRed's Avatar
Veteran: Army
Approximately 1 liter. Our cars are non-limited slip UNLESS the data sheet shows it as an installed option.
Old Jun 24, 2025 | 01:09 PM
rmorin49's Avatar
Veteran: Army
Thanks. I'll check my build sheet but I don't think it has LSD.
Old Jun 24, 2025 | 03:54 PM
Unfortunately, only way to get a LSD in a non-AMG car is to swap your existing diff (easiest) or rebuild it.
Mercedes HAG215 Drexler/AMG Rear Differential assembly (option 471)
AMG Rectifier
AMG Rectifier
Old Jun 24, 2025 | 04:13 PM
rmorin49's Avatar
Veteran: Army
Thanks, CR. Do you have an opinion about the brand and weight of diff fluid for a non LSD diff?
Old Jun 24, 2025 | 04:24 PM
I think the data in this thread is still valid:
https://mbworld.org/forums/sl-class-...il-change.html
Good Luck
Old Jun 25, 2025 | 04:00 PM
JettaRed's Avatar
Veteran: Army
Good Luck
LOL! Talk about regurgitating this discussion. We must all be getting old because I posted several times in that thread and forgot all about it. NOW I know why I had the Castrol Syntrax Long Life and Mobil DELVAC 1 in my garage!
Old Jun 25, 2025 | 04:21 PM
rmorin49's Avatar
Veteran: Army
Same here. I changed the fluid in my diff in 2022 and forgot all about it until I found the order I placed for the fluid. I used the Castrol Syntrax. Now I know I am getting old!
Old Jun 25, 2025 | 04:51 PM
JettaRed's Avatar
Veteran: Army
Well, you’re over due for another. Every 2 years. You can always check with a brake fluid tester.
Old Jun 25, 2025 | 07:43 PM
rmorin49's Avatar
Veteran: Army
Diff fluid? Brake fluid maybe.
Old Jun 25, 2025 | 10:27 PM
JettaRed's Avatar
Veteran: Army
Ugh! I'm getting my threads mixed up. Must be the heat!
Old Jun 27, 2025 | 10:06 AM
LOL! R231 owner demographics…
Now you know why WE aren’t a targeted demographic by Mercedes anymore.
