SL/R231: SL65 AMG 2013 ECU, TCU, ABS, ISM Dead..Help?
Old Aug 5, 2025 | 10:03 PM
MKEDF's Avatar
C230 Kompressor 2005
Exclamation SL65 AMG 2013 ECU, TCU, ABS, ISM Dead..Help?
Hello, im trying to fix my SL 2013 with 19,000 miles with this issues
NO START, NO. CRANK
WITHOUT CHANGING GEAR READ MANUAL
ABS NOT WORKING
NO OIL MEASUREMENT POSSIBLE
AS i Scan with a Thinkcar scanner i get errors ECU is not responding, ABS Not responding, TCU not responding, ISM not responding.
Car does not allow to change gears and is like blocked
Other Modules such as Front SAM or Rear SAM shows no error
Looking for a Pinout Diagram out of A 279 900 19 00 AMG Motronic ECU To find out more about power issues.
Also looking in to web ETM web site, diagrams available but not PINOUT.
Any one with this issues?
ISM DTC U119800
C10087 DTC FOR ECU
U010087 DTC FOR ECU
P060C04 DTC FOR ECU
Plus other errors related from other modules
Any help, is welcome..
Best!
Old Aug 5, 2025 | 10:57 PM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
Has the car been sitting?
Battery(ies) status?
Originally Posted by MKEDF
NO START
Does the car crank over?
Old Aug 6, 2025 | 01:12 AM
MKEDF's Avatar
Exclamation No Crank
Battery(ies) status? The car was running, then blocked, then ran again..
Car is not much used, it is over 19,000 miles
Car was driving well and out of the sudden, no start and error messages on dash
Battery is OK and was charged.
Towed to garage to find problems source.
No it does not Crank Over..
Old Aug 6, 2025 | 01:17 AM
MKEDF's Avatar
Looking for this diagram
Searching for this diagram PE07.08-P-2101-97TAA
Old Aug 6, 2025 | 09:30 AM
See attached .pdf’s. - note: these large diagrams can be tough to digitize. I’ve made two copies, one reduced, but on a single page. You may need to zoom in or refer to the larger multi page version I’ve also attached.
I can’t overemphasize that most of the problems people post with low mileage vehicles are usually something basic. Going down the wormhole, and searching for complex issue’s sometimes leads to circling back to the basics for “the fix”. It’s usually something basic we missed in initial diagnosis….
I’m not saying you don’t have an electrical issue. Especially since we don’t know history. Just make sure you check & double check all the basics (very well) first.
There are a series of fuses also that you’ll want to check. There are MIDI fuses that are difficult to access that can get damaged by water incursion or bad jump start that will create a no start conditions.
Like these:
https://mbworld.org/forums/sl-class-...ml#post8713675
Good Luck.
Old Aug 6, 2025 | 11:49 AM
MKEDF's Avatar
Exclamation awesome!
I can’t overemphasize that most of the problems people post with low mileage vehicles are usually something basic. Going down the wormhole, and searching for complex issue’s usually sometimes leads to circling back to the basics for “the fix”. It’s usually something basic we missed in initial diagnosis….
Like these:
Good Luck.
awe
Thank you so much..will work with this input...so valuable!!
Old Aug 6, 2025 | 05:08 PM
MKEDF's Avatar
Exclamation Wrong Wiring Diagram....PE47.40-P-2101-97RKA correct!!
Like these:
Good Luck.
Thank you so much.....i mistyped, the correct diagram is PE47.40-P-2101-97RKA for a V12 2013 SL AMG Engine. hope you can help with this one...
Old Aug 6, 2025 | 07:43 PM
MKEDF's Avatar
Helllo, can you provide this two diagrams, for ECU and front SAM?
Front Sam Wiring PE54.21-P-2106-97RKA for Mercedes SL 65 AMG 2013
Engine ECU Wiring PE47.40-P-2101-97RKA For Mercedes SL 65 AMG 2013
Engine is 279 in model 231
thank you so much!
Old Aug 7, 2025 | 06:44 AM
jmattioni's Avatar
2014 SL65 AMG, 2018 S560
Step one is definitely to check the starter battery in the trunk. Get a voltmeter and measure voltage at the jump posts under the hood. Should be in the vicinity of 12 volts. Then turn on the ignition and measure again. It should be at least 10.5 volts or some modules are going to malfunction.
Then get someone to crank the engine and measure the voltage. It should not drop below 10 volts.
If the batteries have never been replaced then they are definitely due.
Old Aug 7, 2025 | 10:44 AM
MKEDF's Avatar
Exclamation
Battery on the Trunk has been checked OK Voltage
No Crank and No Gearbox and ABS on Screen, some sort of Limp Mode
Scanner throws ABS, Gearbox, ECU with no response at al...
Looking for ECU Wiring diagram to look for problems
Old Aug 8, 2025 | 07:23 AM
jmattioni's Avatar
Next on the list would be CAN bus health. There's multiple segments to the CAN bus and certain modules act as gateways between them. One of the bus segments may be disabled due to a short or open wire. This could happen because of damage to a harness or a failed module.
The most basic test checks for proper voltages on the bus wire pairs and for shorts to ground. There's multiple locations where you can access bus distribution points. One is in the passenger footwell. There are lots of videos out there providing the basics of how to check a CAN bus.
If you don't have your own copy of WIS at this point you definitely should consider buying one. You will not get wiring diagrams of the internals of the modules, but it does give extensive wiring diagrams, including all CAN bus interconnections, module pinouts, power distribution, fuses, relays, etc.
Old Aug 8, 2025 | 08:13 AM
jmattioni's Avatar
@MKEDF Here's an overview diagram of the CAN bus. It looks like all the non-responsive modules you mention attach to CAN E1, among others. Maybe a place to start.
CAN E1 is referred to as the "Chassis CAN." I've also attached a diagram of the distribution module (X30/30) for that bus.
And a couple more diagrams showing the location of X30/30 among others. Looks like it's behind the fuse block on left side of dash. Or, it may be under the dash, hard to tell.
Old Aug 8, 2025 | 08:41 AM
MKEDF's Avatar
Than, you so much!!.....already working on the MIDI fuses, they are located on right side foot well, under a plastic cover with 3 plastic bolts, the team is searching for blown fuses there.
Next step as you recommend is to find an interruption on can bus, right side footwell also has CanBus coupler as well as OBDII conector has another CanBus...we will start from there...Thank You Will keep you posted.
Sorry That we can not find ECU Wiring diagrams or SAM, they are referred on other diagrams, but not available, power is what we are following here, but will work with what we have..Further details to follow!!
Old Aug 8, 2025 | 09:20 AM
jmattioni's Avatar
I believe the fuses you're referring to are the pre-fuses. Those are high amp fuses for power distribution. There's also a fuse and relay box on the front SAM in engine compartment, rear SAM on Aux battery behind passenger seat, and one on left edge of dash on driver side. LOTS of fuses!
What you're referring to as the "ECU" is the "Motor Electronics ME/SFI" module, N3/10, which is also on the E1 bus. If you don't find fuse issues then I suggest starting with checking out E1. The X30/30 block for CAN E1 should be somewhere in the vicinity of the OBD connector.
Good luck!
Old Aug 8, 2025 | 09:28 AM
MKEDF's Avatar
Exclamation Working on these
Good luck!
Yes already on both things, found fuses un right footwell, under a plastic cover, today will disassemble
Yes right Next to Fuses and OBDII there is a CAN bus connecting point will search as well if no issues found.
Any way if some one has available wiring for ECU and SAM would be appreciated.
Best
Old Aug 8, 2025 | 09:42 AM
Was away from my shop but here you go….
I’ve found sometimes that searching by car instead of VIN can be effective in bringing up documents that won’t show up in VIN searches.
Attached are the documents you’re looking for.
As @jmattioni suggested, and as you know, we can’t overemphasize the necessity of STAR SDS/ XENTRY and WIS for these cars.
Good Luck
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Aug 14, 2025 | 10:09 PM
MKEDF's Avatar
Exclamation
Good Luck
Thank you so much....we have already searched for prefuses and no problems found, now we are checking your diagrams, printed and already on the wall to follow.
We would love to have your support on posting the diagrams related to N3/10 ME-SFI [ME] control unit The ME-SFI [ME] control unit contains the whole engine control.
07.61-P-2101RKA ME-SFI [ME] gasoline injection and ignition system control unit. Sheet1
07.61-P-2101RKB ME-SFI [ME] gasoline injection and ignition system control unit Sheet 2
07.61-P-2101RKC ME-SFI [ME] gasoline injection and ignition system control unit vehicle connector
Thank you so much, still looking for culprit!!
Old Aug 15, 2025 | 09:22 AM
jmattioni's Avatar
Here is the ME-SFI schematic diagram.
Old Aug 16, 2025 | 11:28 AM
Bilbo7's Avatar
2015 SL63 AMG (R231)
Hi
I had that message 2 years ago on holiday. The car had warnings ECU is not responding, ABS Not responding, TCU not responding, ISM not responding but would run after stopping and restarting if below 2000 rpm
Then finally the same message you have.......and would not start
It went to a small dealership near Naples and they changed the gearbox computer
A week later same problem then it went to a main dealership south of Naples that also sold BMW's !
They changed the nearside (UK) front wheel sensor
All fine back though Munich and on reaching Holland IT HAPPENED AGAIN!
We limped back to London on 2000rpm as it was a Sunday
Once home and talking to Ninja Benz and others here I changed both batteries and the problem has not occurred again in over 6.000 miles
I hope this is of some sense and does not cause you more confusion as logically it could have been just the batteries or those and the wheel sensor or the lot!
Its also a sad reflection of Mercedes dealerships but 3 other I have found to be the same and the STAR dealership I use at Maidstone great
Old Aug 16, 2025 | 02:11 PM
JettaRed's Avatar
Veteran: Army
@Bilbo7 mentioned @BenzNinja , who provides remote diagnostic services and can be a huge help. I use a LAUNCH scanner for the small stuff at home, but I also have the SDS (XENTRY) that I got from him for the more complex stuff.
@Bilbo7 is right about the batteries in these cars. They are incredibly temperamental when it comes to voltages. Even if the battery checks out "OK" there still may be problems. The advantage of replacing both batteries at the same time is that you also do a hard reset of all the electronics in the process. I was having a problem where I ended up pulling a fuse and reinserting it and the problem went away (I forget what the problem was, but the fuse was one located in the fuse block behind the passenger seat).
Old Aug 17, 2025 | 08:36 AM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
I really have to echo these statements. First, are you using xentry for diagnosis? It will point to the exact problem... there's no need to do anything it doesn't tell you to do. I would not be paying a shop for diagnosis that does not have this tool as they will just be wasting time. As a diy'er with star/xentry, it has never failed to diagnose an issue for me.
Second, Replace the batteries. This is the primary reason for issues like this and is easy enough to check. A shop should have spare working batteries around for this type of quick diagnostic deduction.
